Question about HP PSC 1315 All-In-One InkJet Printer
The Encoder Strip of my HP psc 1315 was pulled completly out. I have taken the unit apart, but I don't know where the Encoder strip is to be replaced I need some type of a diagram. I noticed that there is little markings on both ends of the strip dots, and a triangle on one of the ends, I'm quite sure this means something.
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Lexmark 6170 encoder strip reattach help needed
There is a spot where the strip goes through and it MUST be in this slot. It might be just a slot or it could be a hole it goes through. On all inkjets the strip will ALWAYS be straight and not pushed either frontward or backward, if it is, its not where is should be.
Posted on Sep 14, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
I have a hp psc 1517 and there is a thin strip of plastic behind the ink cartridges, my daughter pulled it out can it be put back in and if so how
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If your daughter didn't pull it all the way out of the machine it is a bit easier to reinstall because all you need is something skiny and long like a pair of needle nose pliers to reattatch it to both of the mounts. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you intall the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Oct 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
Encoder strip for HP 2175 xi
Here's the solution for fixing a carriage jam on your PSC 2315xi printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&cc=us&lc=en&dlc=en&product=90812 But, you said the encoder strip came off. I always understood that if the encoder strip came off, the printer was dead. I've never tried to take the encoder strip off and put it back on again to see what happens. The encoder strip is what tells the carriage where it is. Without the encoder strip, the carriage doesn't know where to go.
Jun 09, 2009 | HP Office Equipment & Supplies
My HP 1315 keeps printing the alignment page...many times, even t
clean the feeder roller for possible debri and clean the encoder strip located at alongside with the carrier carttridge. It is usualy the done that guides your cartridge for alignment. Also try to inspeact and clean the encoder wheel located at the leftmost side of your printer. This is the timing wheel for paper feeder.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer problem
its a problem of the encoder strip . either the encoder strip is loosened or damaged.the carriage sensor reads the plastic encoder strip while it moves.if the sensor is not able to detect the encoder ,such a problem arises.u can check the position of the encoder and take the necessary step accordingly.if the encodder is damaged replace it.
good luck.
thanks.
Oct 27, 2008 | HP PSC 1410v All-in-One Printer
Encoder strip
If you can access to the encoder strip, try to clean it by damp cloth or detergent liquid. Wipe it with holding the stripe along the way.
Apr 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP F370 PSC
One possibility is. look toward the back of the printer, there is a strip of clear plastic, about a quarter inch wide and clear. It runs the length of the print head area. That contains the stop strip. That strip or the sensor on the print head itself may be dirty and not sensing the strip, therefor not knowing when to stop.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Encoder strip part c8941-80005
Feb 24, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 2410 problem
you can order all components of an HP product from HP's website or through phone.This is the best way to solve your problem. Your question is not complete...though I would suggest you to visit HP's support web page ad all information is available on error codes. This could do more than my advise.
Oct 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP 1315
Sounds like you have a problem with the ribbon cable or the circuitry on the print head assmbly. The ribbon is usually a suspect if the cartridge lights are on. If that doesn't solve the problem check the circuitry.
Mar 05, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
177 people viewed this question
Seeker5211
Seeker5211
