Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
NEED NEW CHAIN DRIVE UNIT INCLUDING PLASTIC
NEED THE BEST SITE TO BUY A NEW CHAIN DRIVE UNIT INCLUDING PLASTIC SPROCKETS FOR A 028 WB STIHL. THE SAFETY BAND OF THE SAFETY STOP KICKED IN CREATING SO MUCH HEAT THAT BOTH PLASTIC PLASTIC SPROCKETS MELTED.
ALSO IS THE UNIT JUST PULLED OFF THE SHAFT AFTER THE HOLDING SPRINGS ARE REMOVED?
  • 148 Answers
The model 028 Stihl Chainsaw was in production for many years and the clutch drum sprocket (or chain drive) came in three (3) versions over the years of production.
For several reasons, it is best to take the saw to an authorized Stihl Dealership (Locate your nearest dealership HERE) for production identification, evaluation of cost-effectivness and availability of parts.
Reason 1) The first-generation 028 saw is approaching 30 years old.
Reason 2) Extreme heat caused by a locked chain-brake can damage the engine case and render the saw unfixable (part support is going away due to age).
Reason 3) The shear cost of parts and amount of time it would take for a DIY repair.
Reason 4) The plastic gears you mentioned are the drive system that make the chain's oil pump work. If the plastic is melted, the oil pump is likely to be damaged as well. In most cases the oil pump cover gets damaged ... the list goes on and on.
Genuine Stihl parts are not sold online and aftermarket parts would be a gamble. It's up to you to decide if the cost, time and effort are worth it.
Hope this helps.
Posted on Oct 04, 2009
I need to change the drive sprocket on a 028 av super i am having problem getting the old sprocket off whats the trick
is the chain brake still applied, thus gripping the drum on the sprocket.. Remove the E-clip and take the chain brake off... clutch drum should lift out.
Sep 15, 2012 | Stihl Garden
Replacing chain gear drive 028
It just pops off, keep tugging. Same for an 038
Nov 13, 2011 | Stihl Garden
How do I repair the oiler on my stihl chain saw model 028
You have to remove the little white gear to be able to get to the screws to remove it.
Apr 10, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Where do I find a operators manuel for Stihl 028 WB?
GO ONLINE TO STIHL AND THEY HAVE A PDF SECTION YOU CAN DOWN LOAD OR PRINT
Dec 31, 2010 | Garden
028 wb how do you gap the points with the flywheel removed
You need a cam tool--probably easier to see your Stihl dealer and have them set the points. Good luck!
May 04, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 028 Gas Tank off?
Any other manufacturer I would provide a link to an IPL. Stihl considers them proprietary.
Go here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A bunch of folk that enjoy all chainsaw. Please try search, find an applicable thread and join the conversation.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Search for your saw and send a PM to an active member that replied to a similar request works best.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 17, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Stihl chainsaw 028 wb will not start it has spark, but always floods, I cleaned the air cleaner
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Feb 02, 2010 | Garden
I need a fuel hose diagram for a stihl model 028 wb chain saw.
Stihl IPLs (exploded parts list) are propriatary, You can request one here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
http://www.stihlusa.com/contact.php
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Dec 23, 2009 | Garden
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
204 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
