Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Choke/start knobs wont pull out to ingage thus not start.saw is only 6monthsold used twice
    President:
  • 2,220 Answers
Should still be warranted. Why void the warranty? Take it back or find an authorized service center.
Poulan.com
http://www.poulanpro.com/node4042.aspx
The site says 1 year warranty. HTH
Lou
Posted on Oct 05, 2009
How do you chage a choke knob on a poular chain saw
If the knob is attached to a cable you will need to replace the entire cable which comes with the knob attached. You can just follow the cable and determine how to route the new one and attach it the same as now to the carb.
Jun 17, 2014 | Poulan Pro 260 Chain Saw Av Springs,...
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Had difficulty starting chainsaw DCS4610 for the first time. Think it was flooded. Problem now it wont idle.
Is this a new saw? If yes return it or at least ask for a recommended repair facility. Your saw is actually a Dolmar (owned by Makita) and a fine saw. In order to meet EPA requirements they are set very lean (many 5100s seize with factory settings). To protect your investment and not invalidate your warranty I recommend it be adjusted by the
professional recommended by the merchant where you purchased it or one recommended by Makita.
The starting procedure is probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Most new owners miss opening the choke after it tries to start or do not hear the pop when it does and flood the saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
M842 chainsaw wont start when hot
I suspect your warm start procedure is the fault, the manual is not correct IMO. Any choke on a warm engine causes flooding, try this, if no better post back or return it for warranty replacement.
Start Procedure
Cold:
Warm:
Lou
Mar 13, 2010 | McCulloch Garden
Husky 254 xp spark from plug but will not start plug seems to be wet
If the plug is wet the saw is flooded. Try the following to clear that condition.
Extreme Flooding by Dolfoff; Please follow this link,
http://www.fixya.com/support/t3226410
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button.
Once the flooding condition is cleared this start procedure works for every saw I have (7). Please read line 3 twice; both cold and warm.
Start Procedure
Cold:
Warm:
Good Luck. HTH
Lou
Feb 27, 2010 | Husqvarna Garden
I have a 2150 poulan that wont start. gets gas and spark plug fires
Read your manual cold start procedure carefully, especially the second note. IMO open the chock (not 1/2) once it tries to start and I think your problem will be solved. Try this start procedure I think it works better than the one in your manual.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed or 1/2.
I am going to close this. If no better post back (below) and we will get into some trouble analysis. Yours is a better than normal question, Thank You
Lou
Feb 21, 2010 | Poulan Garden
Wants to start but wont appears as if it is flooding fuel coming out of exhaust
Take it outside away from structures. Open the choke. Leave the ignition off. The possibility of fire is high; please be cautious. Remove the plug. Hold the saw with the open plug hole parallel to a drain pan and at the lowest cylinder orientation possible. Pull the starter slowly several times (MAKE CERTAIN THE IGNITION IS OFF FIRST). Drain as much fuel as possible. Put it aside with the plug still open for quite a while.
Find and read the start procedure in the operators manual. Probably similar to this:
Start Procedure
Cold:
Warm:
Install a clean fresh plug. Use your Warm start procedure (it has lots of mix already DO NOT try to start with the choke closed. If it still floods It is probably time to visit your friendly neighborhood Stihl mechanic. You can reply below and we can continue if you like. Good Luck, I hope you found this helpful.
Lou
Jan 20, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
105 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
