Question about Linksys Wireless-G WRT54G Router
Wht can the problem be when i can see my SSID,
What can the problem be when i can see my SSID, with very good signal strength but cannot get on the internet (WRT54G.
  • Christa Harold
    Christa Harold May 11, 2010
    Can you get on through a straight cable connection to the router? If not I would test my modem connection first. If you can get on then make sure it is handing out IP addressess. Try setting the ip address manually to the machine that is not connecting and see if you get anything then. Rebuild the stack or use the WINSOCK repair tool. There are many things it can be so let me know what you have tried and haven't tried.
    Problem Solver:
  • 7 Answers
You may have the Broadcast SSID turned off on the router.
If this is the case and you try to connect you will not see your network to connect to.
Posted on Oct 05, 2009
    Champion:
  • 201 Answers
If u cannot connect to the internet, 1st make sure the power LED is not flashing, if it is flashing then power off all your connection device: DSL modem, Router and computer. After that, power on each device in following order: DSL modem->Router->Computer.
Another that u can check is the cable connection. Since your computer can connect to router, then the rest to check is the DSL modem must be connected to the internet port on the router and coaxial port to the telephone line.
YBC (/\)
Keep losing signal
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 28, 2013 | Computers & Internet
My wifi doesn't work.
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 08, 2012 | Computers & Internet
D link keeps loosing signal
Sep 19, 2012 | D-Link DIR-615 Wireless Router
My router signal is not strong enough to connect ps3 which is in another room
There are a few things thatcan cause you to lose wireless connection with your wireless router. 1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up. 2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router. 3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Aug 11, 2011 | Computers & Internet
Why do i keep getting disconnected
Mar 23, 2011 | AT&T Computers & Internet
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
What is SSID?
SSID means Service Set Identifier
SSID is the network name setup on router to be Recognised.
This can be Default name like the router name or a name specified by user
Oct 07, 2010 | Office Equipment & Supplies
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
Dec 26, 2009 | Acer Aspire One PC Notebook
I cant seem to pick up a very strong signal. Do i need an antenna booster?
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Linksys Wireless-G WRT54G Router Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
