Question about Samsung ML 1710 Laser Printer
Printing problem: Samsung ML 1710 Laser Printer
Dear sir, When I print, I get the print with missing/partially blank lines from top to bottom somewhere in the centre. What could be the solution? KR Mani , email id: s.kr.mani@gmail.com
  • 22 Answers
Hi Krmani,
The problem is because ink in the catrdige might have almost completed, would request you to get your catridge filled with ink ( black and color respectively), the below link will take you to dial a toner page of samsung, you can callup their head office or can furthur search for a store near to your place with help of map, Samsung tone partners charge your bit more compared to generic brand, if you would like to buy a generic brand just walk in to any ink filler shop near your place that even would do, but for longer and effective output from your printer would recommend you get your catridge filled with samsung ink....
http://www.samsungindia.com/where_we_are/index_wcms.asp
Please let me know was this post useful, by providing your valuable feed back .
Posted on Dec 23, 2007
I have a Samsung 1710 laser printer. It prints the text fine but there is a 1/64 (aproximately)wide vertical line of broken printing on the right side of each page. Also, the paper does not appear to be...
Sounds like the printer cartridge is bad. The first thing I would try is replacing that and then see where you are. The broken line on the right side is likely due to a worn imaging drum coating, common with Samsung.
Feb 05, 2010 | Samsung ML 1710 Laser Printer
Horizontal lines appear every 4 inches on each
User manual page 6.17 says:
Horizontal streaks indicate improperly installed or defective toner cartridge. Try re-installing the cartridge.
http://downloadcenter.samsung.com/content/UM/200607/20060712143739406_ML-1710_English.pdf
Nov 28, 2009 | Samsung ML 1710 Laser Printer
"Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
  • The printer cable is loose or defective.
  • the wrong printer driver was selected.
  • The software application is malfunctioning.
  • The operating system is malfunctioning.
Have a nice day!
Oct 25, 2009 | Samsung ML 1710 Laser Printer
I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Jun 12, 2009 | Samsung ML 1710 Laser Printer
Samsung ML-1710 Printer - see below
Try to put new cartridge in.If this doesn't fix the problem, it can be that the fusing unit heater roller teflon coating is worn out and this roller needs to be replaced.
Apr 28, 2009 | Samsung ML 1710 Laser Printer
Printer prints too light
dust in the LSU (laser unit), you have to clean LSU.
Nov 25, 2008 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Feb 19, 2008 | Samsung ML 1710 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Printer samsung ML 1710 do not power on
If you pulled the envelope backwards, most probably you moved one of the paper path sensors out of position. Unfortunately, this is something you should not try to fix yourself, but any experienced printer or electronics technician can help.
Mar 22, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
100 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
