Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
Anonymous
Level 2:
Novelist:
  • Expert 157 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
157
Questions
0
Helped
63622
Points
448
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
1helpful
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
1helpful
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
2answers
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
2answers
Sony Grand Wega KDF-E50A10
The lamp light does not have to flash on this set for it to be the lamp, and most likely it is just that, the lamp. These sets when the lamps get weak they will do exactly what yours is doing.
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
1helpful
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
