Question about Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5)
File sharing isn't happening
I recently bought a dynex wired router for my home. i have two computers and a laptop and i want to be able to file share but they won't let me. i have turned file sharing on in the control pannel but the computers aren't listed in the network section of the other computers.
    Problem Solver:
  • 17 Answers
1. computers must be on the same workgroup. 2.network connections must be enabled. 3. Local Area Connection Properties must show file & print sharing in the list & checked. 4. TCP/IP settings set to obtain IP address automatically. 5. In advanced TCP/IP settings the Wins tab Netbios is set to default. hope this help.
Posted on Oct 04, 2009
    Guru:
  • 597 Answers
You need to go to control panel and into system, Click on teh Computer name tab and give each computer it's own name if it doesn't have one already. Then click on the change button and give your workgroup a name. Make all computers part of the same workgroup.
I have a wireless router (WNDR3400) connected to a switch (about 10 computer connected to switch), and the switch is connected to the modem. For the network, all the wired computers can see and share...
Make sure all the computers wired and wireless are in the same workgroup.
To share files across all the computers and laptops on your network then -
All the computer and laptop in this network group must have their hard drive or folder/s set to SHARED (a hand symbol will be placed on these folders that are shared).
If there isn't a secutity problem then these folders and easy of file sharing then do not setup users and passwords on these folders.
Apr 18, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
Just bought a acer labtop can not get the hook up to computor
To network two computers you normally need a switch or a router to act as an intermediary between the two computers IF you still want both to have a functioning internet connection.
Otherwise, take your laptop and plug a Ethernet cable into the laptop and into the back of your computer tower.
I'm assuming you are using windows so go to control panel > network and sharing > Homegroup Options > Join now. This will set up a home network for the rest of the computers connected to share pictures music and other files. You will need to access the homegroup password from Control Panel > Network and Sharing > Homegroup Options. Take that password and add it in to your laptop under the Homegroup menu and you will see your laptop underneath the My Copmputer> Homegroup tab in the side panel. You can begin sharing files between them.
Jul 20, 2011 | Acer Aspire One PC Notebook
1 connected ethernet cable from modem to dynex hub in "uplink port", ran another ethernet cable from laptop to 2nd port on dynex hub and ethernet cable from ps3 to 3rd port and nothing happens. Please help...
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Oct 23, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Wireless Laptop and Wired Desktop cannot communicate
Simply printer sharing should be enabled on both computers as well as file sharing.
Helpful Links
Printer Sharing
Jun 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can't share files/folders between networked computers...
I can answer this but I'm kinda winging it so you will have to figure some of this out for yourself.
By default, XP does not let you share your data over the network. Go into folder properties and enable simple folder sharing.
Go to control panel/network and enable file and printer sharing for your network adapter. Reboot and go.
Mar 31, 2009 | Datamax Power Supply (120 VAC with Power...
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
Computer file sharing
first check,
laptop and pc is in same workgroup.
then,Right ckick on the file---------------share and security-------------cilck on blue under line like if you understand security risk....................................--------------then choose just enable file sharing---------ok
its done!
Jan 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
Aug 30, 2008 | 2wire 1800HG Router (RG1800HG00)
Computer and PS3
you just need to connect your ps3 to one of the ethernet ports of your dynex router and you will be able to share internet connection with your boyfriend
Jul 04, 2008 | Dynex DX-E401 Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5) Logo
220 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
