Question about Optoma Televison & Video
Cannot advance from page to page. Other buttons on the controller seem to work, i.e. menu etc. The page up and page down buttons don't seem to
I'm having a problem with a remote for a Sylvania SRT 2113 too...it won't work. Dead as a door nail. I tried new batteries, and even tried a new universal remote. I tried every code in the universal remote's manual, but nothing worked. Then I saw something that said if the device doesn't have an infrared port, the universal remote won't work. So apparently the TV doesn't have an IR port. I ran across a place on the internet that sells replacement remotes: www.replacementremotes.com. I searched for the SRT 2113 on the website, and made sure the remote that came up included the SRT 2113 on the list of what the remote will control, and it is. So I ordered it. I won't have to program it or punch in any codes to make it work for the SRT 2113, so it should work just fine. Hope this helps.
Posted on Oct 21, 2009
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Aug 03, 2014 | ASUS Computers & Internet
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
I received an LG 32LX4DC Flat Panel Television from a hotel. It came with a control box LG LST-4100A. I saw on fixya.com the method to access the installer menu. However, I could not get the hidden menu...
Just an FYI if anyone is having this same problem a factory reset will solve the issue.Follow the above directions... "1. Press MENU repeatedly till it seems to not respond. 2. Enter 2-6-6-3 on the remote then Enter 3. At the top, it says ENTER PASSWORD 0000 4. Enter 9-8-7-6 then Enter 5. Installer Menu comes up scroll through the options until you see "factory reset" change the value from a 0 to a 1 with the arrow keys and then power the TV off. When you turn it back on it should be reset to factory defaults.
Mar 20, 2011 | LG 32LX4DC 32 in. LCD Television
Would like to program harmony 670 to go straight to HD channels with customized button. Can I?
Hi. I am not sure if the Harmony 670 has sequences, but I think it does!
1. In the 'Customize Buttons' page, click 'Add Sequence'.
2. Name yout sequcence someting (i.e. FOX)
3, Add the number commands you need
4. Click 'Save'
5. In the 'Additional Buttons' tab, type the name of the button (FOX)
6. Select 'Sequence' from the device drop down menu
7. Select 'FOX' from the command drop down menu
8. Update the remote.
Mar 21, 2010 | Logitech Harmony 670 Advanced Universal...
Do you have the instructions for dokapon?
Hi....here it is:
Gameplay Controls Printable View Dokapon Kingdom GAMEPLAY CONTROLS:
wii_dir.gif Control Pad Move. Move Cursor. Up = Magic (Battle). Left = Strike and Counter (Battle). Rock (Roshambo). Down = Skill (Battle). Give Up (Battle). Scissors (Roshambo). Right = Attack (Battle). Defend (Battle). Paper (Roshambo). wii_a.gif A Button View Shortcut. View Space. Open Help Menu. wii_b.gif B Button Bag Shortcut. Display the World Map. wii_1.gif 1 Button Cancel. Movement Shortcut. Data. Show Information. wii_2.gif 2 Button Make Selection. Confirm Message. Stop Spinner. Show Available Moves. Speed Up Cursor. Show Predications. wii_minus.gif - Button Flip Page. Switch Between Opponents. wii_plus.gif + Button Data Shortcut. Flip Page. Switch Between Opponents.
Aug 05, 2009 | AIA Dokapon for Game Boy Advance
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
Adobe Acrobat Pro 7.0 Can't get page numbers to show
OK, That's why it's not working.. In order to get them on there, do the following:
Once you have loaded the page into acrobat, goto the Document Menu, mouse over header and foot, and choose add..
In there, there will be a button that will say "insert page number", just click on that (only once), then click "ok".. That will add page 1...2...3...4, etc to the top of every page.
As a side note: you can also choose where to put the page number by clicking in one of the text boxes marked "Left Header", "Center Header", etc.. and then click on "insert page number".. You will be able to see a preview first before actually adding the numbers..
Mar 29, 2008 | Adobe Acrobat Professional 7.0 for PC
Reviewing my pics on the camera
Chech the manual to see if there is a sequence control. Or how the button load images. For example taking a typical example[any camera] The left right button will advance one image or back one image at a time. But the up down button will advance them in blocks of ten[or 5 or 20] according the to camera model. But if it does seem that a button is stuck on This 'button' may not the the mechanical button you push but an electronic one. Run the through the manual and if still not getting any joy contact the customer support at Canoon
Jun 07, 2007 | Canon PowerShot A520 Digital Camera
Televison & Video Logo
254 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
