Question about Princeton Digital VL1919 19" Monitor
Princeton Monitor VL1919 won't turn on during boot up.
    Scholar:
  • 67 Answers
Try the monitor with another computer or with a laptop (as an external monitor). If it is working, the problem is related to the main unit. This case, have the main unit be checked by a professional.
Posted on Oct 04, 2009
VL1919 blue light flashes continuously, monitor does not turn on. . . even after DAYS of flashing. : (
That is the problem with the standby section of the power supply. A continuous flashing indicate a shorted component usually a small diode.
May 24, 2011 | Princeton Digital VL1916 19" LCD Monitor
HELLO, I have Princeton VL1919 monitor. Recently, the monitor is in the sleeping mode and does not display anything from computer. How can I wake it up?
If your trying to wake your computer/monitor up try pressing a button on your keyboard or move your mouse. This should wake up both your monitor and computer.
Mar 15, 2011 | Princeton Digital Computers & Internet
Screen isn't coming on. I have a Princeton VL1919. The blue light blinks when on and the screen is just black. I have tried it on all 3 of my computers and it won't work. Any help would be awsome. Thanks
Common failure on the Princeton monitors are caps failure in the power supply, look for bad caps (bulging top or seal), see failed Princeton monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Princeton Digital VL1919 19" Monitor
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Feb 23, 2010 | Princeton Digital VL1919 19" Monitor
This monitor refuses to boot-up and in the past it took a long time,Now I get nothing and another same unit has a popping sound and also does not work
you need you power supply repaired. poping is usually bad resitors. take it to a shop or remove the back cover and look at the power supply and replace bad componets
Dec 30, 2009 | Princeton Digital VL1919 19" Monitor
Where can I find the driver for a Princeton VL1919 monitor
Princeton Graphics VL2018W monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly. I agree with this statement. You dont need drivers for monitors 99.9% of the time. Usually you video card is what is wrong if u cant change the resolution.
Jun 05, 2009 | Princeton Digital VL1919 19" Monitor
Monitor dark for 20 minutes before turning on
My VL1919 has been having this issue off and on for a month or so now. It happened three times in one day today, so I decided to do something about it. I opened up the monitor and poked around a bit.
I found three electrolytic capacitors on the backlight inverter board were bulging, two of which had just started to leak: 71706a0.jpg The capacitors were placed directly above and next to a large, flat metal heat sink. I say above with respect to the flow of air due to convection, and next to because the heat sink also wraps around, enclosing the group of capacitors on one side. The heat sink sits flush with the circuit board, turning the board into a front enclosing face. When reassembled, the metal housing sits a fraction of an inch above the sink, forming a back face. This assembly is at the top edge of the circuit board, so the housing then takes a 90° bend to form a top face. These capacitors seem to get almost no air flow... Together with the heat coming off the sink, it appears the engineers have created their own little capacitor oven. Capacitors immediately adjacent to the affected components, but without blocked air flow looked completely normal. Looking at the traces on the circuit board and location of other components, the capacitors could have easily been moved out of the hot spot. This is either an act of gross negligence, or an intentionally created post-warranty failure point, designed to avoid market saturation. But that might be too pessimistic... "Never attribute to malice what can be adequately explained by incompetence." Anyway, I scavenged a few capacitors off an old computer power supply to replace the damaged parts (one 470uF 25V two 1000uF 10V capacitor, both rated to 105°C). To avoid a repeat performance, I soldered some short extension wires to the replacement caps and moved them out to an open area of the board, being careful to give the high voltage components plenty of breathing room. After reassembly, the monitor powered right up and came online. I guess the real question is how long it will stay this way.
Apr 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Jan 26, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL1919 19" Monitor Logo
445 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
