Viewsonic N5230W would not turn on? - Televison & Video
    Guru:
  • 597 Answers
Troubleshooting No Power/No Video Issues:
  • Disconnect and securely reconnect the Power Cable. Then retry the Power Switch.
  • Try using another Power Cable. Most Computers use a similar power cable.
  • Check the power source using another electrical device (like a radio) to make sure the power source is supplying sufficient voltage.
  • If the monitor is plugged into a power strip or extension cord, try connecting to a dedicated wall outlet.
  • Note that some models have a main power switch on the back side, confirm it is on the ON position.
  • If using a remote control, make sure the battery is properly installed.
If the LED is on, but there is no video, use the following links for troubleshooting: If there is some other problem with your monitor, please provide a more detailed description below.
Posted on Oct 04, 2009
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
ViewSonic N1930w-2M turning on in gray in stead of color and will not link to computer
Sounds like like the viewsonic has seen it's better days or the Video Card in the computer is bad. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays correctly, then your original ViewSonic is bad. If the Borrowed monitor does the same as your original ViewSonic, then the Video Card in the computer is bad.
May 16, 2012 | ViewSonic Computers & Internet
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
Monitor turns on and off
Is it an HP or a Viewsonic screen ?
Either way, looks like a power supply problem to me, some Viewsonic screens are known to have a problem with their inner power supply card, If your screen is still under warranty I suggest you don't lose time analysing the problem and just make them come and fix/replace it
Nov 06, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
