Question about Panasonic DMR-E85H DVD Recorder
My DMR-E85H recorder is "frozen" at PLEASE WAIT. What can I do to reset it? Thanks.
There are several causes that can contribute to the please wait error. The most common seems to be the capacitors, but after replacing them, you might still find the please wait error, as was the case with mine. Upon further review, and after acquiring the service manual with schematics, I concluded that the switching IC 1150 was not properly functioning, switching on and off to provide the pulsing current through the primary windings of the transformer. Upon additional review I found that the reason IC1150 failed is because it had over heated because the fan had quit working. With the fan not working, IC1150 quickly over heated, causing the power failure in the power board. If replacing the caps doesn't correct the problem, consinder looking at replacing IC1150, but first, find out if the cooling fan failed to work, causing the failure of IC1150
Posted on Mar 06, 2011
  • 98 Answers
Manually open and remove disk if there is one inside (dirty or fingerprint disks) will cause lock up of Please Wait
Posted on Oct 05, 2009
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
"Please wait" ... panasonic dmr-e85h seems frozen
Have you tried unplugging it for a couple of minutes?
Aug 25, 2009 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
May 30, 2009 | Panasonic DMR-E85H DVD Recorder
Frozen on the Please Wait
This is a hard drive failure and is expensive to fix, and not worthwhile in my opinion.  Mine packed in with a disc stuck in the disc drive. It was difficult to retrieve. If you have no disc trapped in the tray, I would suggest dismantling anyway and removing the hard drive if you have a load of unwatched content recorded. You can buy a cable to hook it up to a PC - Although I have not done this yet.
DMR-E85H - Rest In Peace.
Mar 18, 2009 | Panasonic DMR-E85H DVD Recorder
After apprrox 5 mins unit switches off
Not sure if this will help, but mine acted up similarly before it went with a message of "Please Wait" on the display at all times. Searched the web, found out two capacitors needed to be replaced. My brother was able to easily solder the parts in a very short time. Google the name and model number with the words Please Wait and you can see how many folks have had this problem. Your machine may be on its way to this problem.
I have good friends that got their machine at the same time. Same thing happened to them within one month of me telling them about it. Our machines are about 4 years old as well.
Another big problem. I then got a U99 Error Code. Completly frozen machine. From my researcy I may have caused the problem by storing too much on hard drive. Once you transfer video, get it off the hard drive. They say mine can not be fixed. Problem is, they do not make them anymore. No hard drives for recording or dubbing DVDs.
Jan 24, 2009 | Panasonic DMR-E85H DVD Recorder
PANASONIC DVD RECORDER DMR-E85HP
Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
Can I learn to replace the capacitors on my DMR-E85H
Try to reheat the power supply section.2nd what kind of capacitor is that is it polaryzed or non polar?
Mar 17, 2017 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
506 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
