Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
We are trying to disassemble the head/agitator assembly to clean it due to chalk being run over with the vacuum
  • 13 Answers
I would not try to take apart machine unplug and use damp cloth clean underneath take off clear cylinder gently knock body dust and chalk will fall out.
Posted on Oct 04, 2009
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
Fein fmm250q not oscillating.. How do I disassemble the head?
Special be carefull with the 4 torx screws if you decide to disassemble the head because all the material of this machine is very soft before you know its broken its also not a expensive Fein model but a nice machine for that price . take a hand screwdriver with direct the right size to feel if its correct fit because its to late if a screw breaks. yes its having very soft material screws, the head cannot have a disassembling its a complete part and if that is complete but all by all decide if you think its worth to replace beware of the price , the price is marketing technically adjusted for this machine and expensive and not made to dissasemble in a bench vise you can all things try to disassemble but re-assembling with new spare parts is not deliverable. only complete . 1 little bearing gives the little eccentric rash on the head , i have i all the time i repaire tools not one time that a head of this tool was defect if you can move the lever free and smootly you can solvent clean and after that lubricate it again but re connect the bearing fronttop machine between the space in the lever set the head in a bench vise fixated that the lever is correct in the center position , and then mount the machine slowly on the head again and if its run mount a attachment or blade and control it again .
Jun 09, 2015 | Fein Vacuums
HOW DO I REASSEMBLE CYCLONE ASSEMBLY DYSON DC11
Dear John,
Thank you for your inquiry. We do not recommend disassembling your cyclone assembly, as a result there is not a diagram available. However, we would like to provide further assistance. Please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Jul 24, 2012 | Dyson DC11 All Floors Bagless Canister...
The check bag light comes on and vaccum quits but bag is not full. We changed bang anyway but vaccum would not start.
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Nov 23, 2010 | Electrolux Guardian Bagged Canister Vacuum
My vacuum stops showing "bag full" even after I
Nov 21, 2010 | Electrolux Epic 6500 Vacuum
Our Electrolux Epic Series 6500 SR reads the bag is full and shuts down even though the bag was just changed
Nov 21, 2010 | Vacuums
Why does the belt keep breaking on my kirby
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
May 06, 2009 | Kirby G6 Bagged Upright Vacuum
Fixing my vacuum cleaner
Check to make sure that your agitator still spins. (Agitator = brush). If your agitator still spins, it eliminates your belt and agitator as likely culprits. The last possible solution would be that your vacuum is clogged. The grinding sound might be a motor-related issue or could possibly mean your bearings are going out. Check the bearings of the agitator and the motor of the vacuum.
Accessing to the agitator and belt can be done by removing the bottom cover of your vacuum. There are 2 scews that are holding the bottom cover to the head of the unit. Remove these 2 scews and the bottom cover should snap off.
Mar 07, 2008 | Vacuums
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozzle housing.
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
Jan 10, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
192 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
