Question about HP DeskJet 6122 InkJet Printer
Printer is printing off center....the right side of the page is getting cut off
MUKHTAR
  • 2017 Answers
SOURCE: Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
bye
Posted on Nov 30, 2007
  • 186 Answers
SOURCE: HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Posted on Dec 31, 2007
SOURCE: HP 3050 Black Line
did you copy or print from computer? if on copy time only, you must clean scanner bail, if for both ( copy and printing)your toner is damaged maybe.
Posted on Mar 18, 2008
joelmar
  • 96 Answers
SOURCE: double side printing issue with HP 2420
Try to default on your page setup.
Posted on Jun 16, 2008
  • 66 Answers
SOURCE: HP3600N color fade
It is using the colours to make the grey and the proportion is not correct. Do a calibration.
Posted on Jan 09, 2009
Hp printer printing off center
Try uninstalling the printer completely and if you have a current install disc compatible with your operating system then re-install with that. It may prove better if you go to the manufacturer's website, click on support and follow directions that will be there to identify your printer and download and install the latest drivers. When installing disconnect the USB lead until the program asks you to plug it in. God luck.
Nov 29, 2013 | Lexmark Z705 Inkjet Printer
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
Px650 not printing full page, cutting print area on right
you can maintenance ................. cleaning or deep claening ......click
it is in page set up ................. main........ preferences...
Nov 18, 2013 | Epson Stylus Photo PX650 Multifunction...
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
Printer cuts off 1'' off print on the right side of paper all the time. It doesn't matter what our margin settings are. What could be the problem?
Print a test page by holding down the UPPER LEVEL button for 2 seconds.
If this test page prints fine it may be a driver issue.
If the test page has the right side cut off as well then something is blocking the laser on that side of the printer. Most likely place is something around the drum cartridge area. If you are familiar with the printer and this cartridge you can try removing it and checking this area for a scrap of paper or something blocking the laser light from reaching the drum.
Oct 18, 2009 | Samsung CLP-500 Laser Printer
Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
Printer prints off-center when printing from websites. Right side of screen display is cut off and left margin is extra large.
if you are not printing graphics from the site, try doing a "print pre-veiw first to see if that will help, otherwise it will take a little experimenting with the print settings to find out what will and will not print the way you want it to. try also saving the the page to some thing like notepad or such and then trying to print. good luck!
Mar 13, 2009 | Epson Stylus Photo R220 InkJet Printer
Only prints on one side
Hi, You have to remove the Catdriges from the printer and clean both catdriges and the roller. This might sort your problem. Secondly before printing check the pagesetup of the particular file.
Mar 09, 2009 | HP PhotoSmart 7150 InkJet Printer
Not printing whole page
Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
Dec 15, 2008 | Lexmark X2600 InkJet Printer
Optra S 1625 - not printing an inch on the right side of paper
CHECK THE PAPER WIDTH SETTINGS IN YOUR PRINTER SETTINGS ON YOUR PC OR YOUR PAGE SETTINGS TO SEE IF THERE IS A NON STANDARD PAGE SET UP
Oct 18, 2007 | Lexmark Optra S 1625 Laser Printer
HP DeskJet 6122 InkJet Printer Logo
Seeker5211
Seeker5211
