Question about HP Deskjet F335 All-In-One InkJet Printer
The printer says that it's offline and it won't print anything. also, it says it is deleting somthing but it is taking way too long
SOURCE: offline problem...won't print
Unplug it and then re plug it in; I suggest USB connection over anything else; don't worry about self install if you already have done so in the past. In the print > hit properties on the icon for bubblejet > go to the ports tab > scroll all thw way to the bottom and click the "USB" checkbox. and you should be good.
Posted on Aug 30, 2007
  • 1027 Answers
SOURCE: Brother 640 printer says it is offline
Check the front control panel, and there should be a button that is labeled 'on line' or similar. Press it to bring the printer to an on line state.
Posted on Sep 01, 2008
SOURCE: brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Posted on Feb 07, 2009
dagr81
  • 59 Answers
SOURCE: printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Posted on Apr 04, 2009
SOURCE: I can't print anything because my laptop is offline.
OPEN YOUR LAPTOP AND ONLINE THE PRINTER
Posted on Jun 03, 2009
How do i get my printer from offline mode back to online mode
  • Make sure that the printer is powered on.
  • Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
  • Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
  • After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
  • Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
Printer offline flashing light will not delete job
An offline condition can be caused by using third party ink or refilled cartridges.
To delete a print job that does not release the spooler, look at the bottom right of your screen. You should see a small printer icon. Double click on that icon to open the print queue Highlight the failing print job and then delete it.
Don
Dec 09, 2009 | HP Deskjet D1455 InkJet Printer
Printer says i'm ''Offline'' and I cannot print anything.
right click on the printer and click on set as default and try to print this would resolve your issue persist, delete the printer and click on add a device
Aug 19, 2009 | HP Office Equipment & Supplies
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Jun 17, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Printer won't print says it's offline
hi friend
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Deleting Printed Items
go to control panel, open the printer, open the lexmark x5100, select printer menu , then select cancel all documents, do this in offline postion.
also delete content of temp folder c:\windows\temp
Nov 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Feb 29, 2008 | HP Deskjet F340 All-In-One Printer
Offline problem...won't print
Aug 27, 2007 | Canon BJC 2100 InkJet Printer
HP Deskjet F335 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
