Question about Lexmark X4270 All-In-One InkJet Printer
Missing file Recently my Pc showed this message that deleteme.vbs file is missing. How can I fix It.
    Sergeant:
  • 390 Answers
Run antispyware and antivirus programs. Adware and grayware etc commonly messes with these files. Also run a program called regcure or other, to repair any damaged registry entries lilacgerry xxx
Posted on Feb 06, 2008
How to fix a frozen screne
The cause of the freezing, or locking up, of your computer, is due to some either corrupted or missing files. And more specifically, missing or corrupted registry files. These are the files which tell everything on your how it is suppose to work. Basically, they are configuration files. And if these files get corrupted, or messed up, it can wreck havoc.
Sometimes the registry files end up missing. This can happen when you uninstall software from your computer. The software being uninstalled may remove registry files also associated with another program. There should be a message asking you whether or not you want to delete the files as they are associated with another program. Your best bet is to say NO to this and leave the files. If the files end up missing, then the program which needs them will stall, hang, or freeze the next time it tries to run. But there is a simple way to fix this.
By just running registry scan software on your computer, you can find these problems and fix them right away. It will let you know which files are bad, and will fix them to its original state. And it is this simple step which will show you how to fix your computer freezing.
Dec 14, 2010 | Computers & Internet
Freezing frequently ?
Dec 13, 2010 | Dell Inspiron 560 PC Desktop
Kingston USB Drive is showing in my computer but does not exploring & message comes is "I:\CleanVirus.vbs" is missing.
Right click on start button then choose explorer. You can browse your flash drive by selecting it in left pane
Sep 24, 2010 | Computers & Internet
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Feb 04, 2010 | Microsoft Windows XP Home Edition
FILE MISSING FROM MY PENDRIVE.
Your pendrive is infected with AVG.vbs virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Nov 26, 2008 | LG KU990 Viewty
Virusremoval.vbs
Are you comfortable going into the registry, if so , do this:
virusremoval.vbs
1. From the start menu click Run -> type Regedit
2. Registry Editor will open
3. In the Registry Editor, go to Edit menu and press find
4. In the find dialog box type - virusremoval.vbs and press find next button
5. The search will end at some folder in the registry at the key - "userint"; doubleclick it; you will find many paths separated by commas - eg: c:windows/system32/userinit.exe,c:/windo... and so on.
Among those paths you will find "C:\windows\system32\virusremoval.vbs". Delete the path. Ensure that remaining paths are unaltered so that your genuine scripts are not affected.
6. Press F3 (find next) to see if the same path exists somewhere else in your registry. If found again at some other place remove the path there also.
7. Repeat F3 until you get a message that search has finished.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 13, 2008 | Microsoft Windows Vista Ultimate Edition
Start up msg
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives.
Delete "c:\WINDOWS\system32\userinit.exe"
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
On the right side look for Shell which should have value of just explorer.exe.
delete anything at right side of explorer.exe if there is anything.
Under same key Winlogon also look for Userinit which should have value of
c:\WINDOWS\system32\userinit.exe,
Delete all the **** after the comma.
Then
Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Under the same key locate Start Page and delete its value i.e. http://sujin.com.np/
then go to Start Menu -> Run -> msconfig -> Startup tab -> uncheck .vbs files
Restart System
Jul 23, 2008 | Computers & Internet
Error messages
hm sounds like a virus. maybe your antivirus program deleted a virus recently?. try this.
click start->run-> write "msconfig" and the click startup.
search for C:\Windows\system32\Virus removal.vbs and uncheck.
restart the computer.
dont worry about the popup window that popup first time after restart check dont show this again.
second problem.
what dvd program are u using ? try a other one.
it can be that the dvd writer have errors:S
Jul 17, 2008 | Microsoft Computers & Internet
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Jun 09, 2008 | Computers & Internet
Missing file after avg "healing"
Yes easy fixed. Open from my computer then go into folders options and click on show hidden folders option, your system folder should show up then open that folder and youll see the vbs file. Delete it, and all is good !
Jan 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
Lexmark X4270 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
