Question about Shop Vac Vacuums
I have a model number odl 130040, i need a filter but cant find a match
I am trying to find out the size of the filter. The model is C 2006P. It also does not have a brand name, only a D on the side. It takes a cyclone shaped filter
Mellisa, searched the net, very little info. suggest you take vac/filter with you and stop by a vac/repair shop who will be able to see if it matches other models and can set you up with replacement filter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 27, 2016 | Filter Vacuums
I need a recoil starter assembly for a MTD lawn mower 2011 with a B&Stratton 158cc 550 series engine.The model # is11A-A18M055, and the serial# is 1211KA0057
The model number that you posted does not apply to the motor. The motor series that you posted is for a vertical motor that does not match the model. Can you supply more information?
Jun 20, 2014 | Dewalt Vacuums
Changing filters on vacumm cleaning
its pretty staight forward just match old and new filters by part number and replace. without knowing the model of machine and nature of problem this is best info i can give
Jan 14, 2013 | Electrolux Vacuums
Craftsman vaccuum filter
I think you are missing part of your model number. If you go to www.searspartsdirect.com you can enter your model number and it will pull up the correct filter for you.
Mar 18, 2012 | Vacuums
I just bought this vacuum at a second hand store. My girlfriend told me to grab it as it such a quailty product. How ever I can't find a model number or anything else. I need a manual please. Does it take...
I suggest you google what you know. I dont think anyone here can suggest where you can get a manual for a machine you dont even know the name of.
You ask about a bag ... I dont know ... is there one in it now? You ask about a filter, does it look washable?
This 'quality product' is no value if you cant use it, cant get parts for it.
Donate it to the second hand store.
Im sorry to give you this kind of answer.
a
Oct 05, 2009 | Vacuums
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
May 06, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
WAND WILL NOT PICK UP - NO SUCTION POWER. CHECKED
Check out: http://www.dyson.co.uk/support/help.asp?model=SUP-DC14&article=527  and pick the suitable model that matches yours.
Mar 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissel model 6579-3 powerforce
You can download the user manual as a pdf file at www.bissell.com. Just type the model number in the search box.
Apr 13, 2008 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
81 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
