Question about Poulan Garden
I have a weedeater featherlite plus. the check valve is floating in the tank. where does it go?
    Problem Solver:
  • 17 Answers
I am not familar with this brand but i can give some suggestions. this probably goes on the end of a breather line for the tank or on the tank itself. this allows the tank to get air as the fuel is used but keeps it from leaking out when tipped on its side or over.
Posted on Oct 04, 2009
Are there 2 fuel hoses going into fuel tank on a weedeater featherlite plus weedwacker
Yes, your return line and the one that has the fuel filter on it.
Aug 27, 2014 | Garden
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
My brother bought a Weedeater Featherlite Plus Fl26 and lost the operators manual. He says it is a Dual String weedeater and he has to have 2 strings, not 1 to make it work properly. I think it needs...
Well I have used this search engine called google. Though it seems to be unknown on this board I would go there www.google.com and do the following search" Weedeater Featherlite Plus Fl26 manual" This will create a number of hits or links. You click on one that has the company name in the url and find customer service or downloads. Click around and eventually you will find what you seek.
Spread the word about google, it saves a bunch of time instead of asking strangers to do google searches for you.
May 14, 2011 | Garden
I have a weedeater model Featherlite 711334 and the gas lines crumbled to nothing. Not sure how the set up was inside the gas tank as to which line goes where and hooked up to what inside the tank.
There are two lines from the tank to the carburator. One picks up gas and fills the prime bulb, the other is a return line. The pickup line should have a filter on the end of it that is in the tank. The other line just dumps back in the tank. Usually the reason these lines deteriorate is because of ethanol in the gas. Make sure you're using ethanol free gas.
Sep 30, 2010 | Weedeater Gas Powered Hedgetrimmer...
I need a fuel line schematic for a WeedEater brand Featherlite Plus weedeater
Presuming the primer bulb is on top of the carb....Fuel filter line out of gas tank goes to the lower part if carburetor body. The other line (normally larger in size) coming out of the fuel tank goes to the primer bulb outlet on the top of carb.
If the primer/purge bulb is not on the carb, things are a little different. The fuel filter line out of the tank still goes directly to the carb, as the bulb will pull old fuel/air out of the carb allowing fresh fuel to flow in and pushes old fuel/air back to the fuel tank.
Fresh fuel in, old fuel out of the carb...you can hook up a piece of fuel line to the bulb and tell which one is pulling and which one is pushing..or depress it with your fingers on it...either way you can tell.
Jul 04, 2010 | Garden
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Weadeater featherlite plus runs rough and cuts
It could be a number of things, but check the fuel lines first. They may be cracking apart at the gas tank. If so, replace them. There are other things it could be, but lets start there.
Jim
Jun 05, 2009 | Poulan Garden
Garden Logo
155 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
