Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox soda machine not keeping cold - Maytag SkyBox MBV1976A Beverage Dispenser
3 Suggested Answers
  • 66 Answers
SOURCE: Skybox
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Posted on Nov 12, 2008
  • 7 Answers
SOURCE: keeps freezing soda cans
well te best way to fix this is to lower the thing
Posted on Aug 13, 2009
Pepsi soda machine
could be low on freon, drity coil, rear fan not turnig,
Apr 10, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my sky box works but when I push for a soda all
There is a little sensor board in the door where the flapper door is,you can access it when the door is open.That is what tells the main control that the can has fallen down through the door and the door has closed.
Aug 27, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Keeps freezing soda cans
May 29, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Replacement compressor for maytag skybox soda dispenser M#MPV1976AAP
A replacement compressor was NEVER made availible for this product. Be sure the problem is not just the start relay and overload. Buy a SUPCO URCO41 from an appliance parts distributor (www.marcone.com) for about $25.00. The installation instructions are on the package.
May 06, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox soda dispensor does not get cold
sounds like the comp relay is bad or the compressor itself is bad the relay is inexpensive and easy to replace. the compressor on the other hand is not available to be replaced for this unit as well as cost prohibitive.
Jan 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox - Dispense Problem/Lights Flashing
I returned the machine to where I bought it. It not only didn't dispense, it also didn't refrigerate. sorry I don't have an answer for you.
Sep 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Cannot get soda to dispense
Sounds like the child lock is turned on. Have you checked that?
Dec 27, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
524 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
