Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
I've been using a small shop vac in the seller to vacuum up dust, sawdust etc. I have emptied the inside and the filter looks laden with dust. It does not "****" any longer. What is wrong and what do I do to fix it?
    Sergeant:
  • 302 Answers
You have to clean the filter too. Use an air hose to clean it or brush it off with a stiff brush or you can wash it if it isn't paper. As a last resort you can get a new one.
Posted on Oct 06, 2009
How to correct a saw dust problem on a kobalt 10 .dust does not go into chot a 2 shop vac hel
The hole behind the saw blade can become blocked solid with sawdust ( especially if the timber is green or wet). clean out the vacuum hose back to the collector.
Jun 19, 2015 | Shop Vac Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Ridgid shop vac. use filter or not when vac. water
Just use the sponge filter, if wet dust goes through the blades, it will build up, throw it off balance and the vacuum blades will break loose from the shaft.
Jun 07, 2014 | Shop Vac 925-13 Canister Wet/Dry Vacuum
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How to stop dust from escaping the shop vac tub
The only sure fire way is to use a filter, bag and ensure you have what they call a "noise muffler" but in all reality it's a filter that not only dulls the noise but doesn't let dust escape via the access there in the rear.
Apr 15, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair: http://www.shopvac.com/support/
Feb 21, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My shop vac blows dust as soon as it's turned on and throughout use. I have changed filters, nothing is helping. What part of my vac can not get wet, or is there a better way to clean out the system?
there should be a cover or sock over the filter,this will stop the dust.the paper filter is the part that can not get wet. if you don't have a cover for your filter use an old sock or something simular to a sock.
Aug 04, 2009 | Shop Vac 584-04-00 Quiet Canister Wet/Dry...
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
133 people viewed this question
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
