The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
there are some you can download If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information. It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer. But if you create a recovery CD for your computer, the restore process can be much faster and quite easy. Click on the Windows Start button. Click on the Control Panel option. Click on Backup Your Computer from under the System Maintenance section option. Click on the Backup Your Computer button on the Backup and Restore menu. Select your CD drive from the drop-down list and press the Next button. Click the Start Backup button to begin the backup process. you might need to use dvd rw depending on the size of the backup How to Create a Windows 7 System Repair Disc: http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer. or If you do not have access to either disc: Windows 7 - Repair Disc download http://neosmart.net/blog/2009/windows-7-system-repair-discs/ a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot. Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay. c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options. e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected. Note that on your Dual Boot system there now should be only one operating system listed. f) Now from the menu list select the Command Prompt option. bootrec.exe /fixmbr bootrec.exe /fixboot (may return an Eliment not found message) bootrec.exe /RebuildBcd i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup Repair cannot repair this computer automatically. Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair. This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart. Reboot the computer. http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
Put the blank CD in your CD writer.
b) Select the correct keyboard input method and click Next.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
Click the Next button.
g) At the DOS prompt type the following three commands
h) Close the command prompt window and click the Startup Repair option.
These messages are the result of the radical changes made by removing the other drive.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
vista recovery disk
not longer free
hope this helps
Insert the Windows 7 installation disc or USB flash drive, or a system repair disc, and then shut down your computer.
Restart your computer using the computer's power button.
When prompted, press any key, and then follow the instructions that appear.
On the Install Windows page, or on the System Recovery Options page, choose your language and other preferences, and then click Next.
If neither the Install Windows page nor the System Recovery Options
page appear, and you're not asked to press any key, you might need to
change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
If you are using the Windows installation disc or USB flash drive, click Repair your computer.
Select the Windows installation you want to repair, and then click Next.
On the System Recovery Options menu, click a tool to open it.
