Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Smokes when i crank it up and when i engage mowing lever. Smokes from exhaust. just bought mower. It is a lts 2000 09' model. Bought from sears, mower was shortly owned and used.
  • 472 Answers
What moter do you have on let me know ok hey ck the oil it may be over full it wont hurt it you just need to get the level right let me know
Posted on Oct 04, 2009
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
PTO stopped while mowing and will not re-engage. It looks like the lever to activate it goes to a switch just under the dash
There is way to many different ways these engaging levers operate to be able to be very helpful without know make and model of the mower.
Oct 02, 2013 | Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 46", 21 HP Craftsman riding mower. The
perhaps it is no oil or too much oil. Check oil level!
If it was too much it would be blowing oil or blue smoke out the exhaust.
Good luck! Hope this helps.
Ashman
Jan 03, 2011 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not engage
Lever that adjusts height does not make blades turn. You need to engage the blade lever and if you can not tell if the blades are turning then they probably aren't. check belt it could need replacement.
Apr 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
186 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
