Question about DeLonghi Irons
Deloghi ironing system (VVX810) when steam button pressed - dirty stean/water comes out of iron making items to be ironed. Reservoir flushed out several times - clean water comes out - also iron shoots out water as well as steam.
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
protek480
  • 1723 Answers
SOURCE: brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
  • 699 Answers
SOURCE: dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Posted on Feb 24, 2010
My iron is not releasing steam at all. The motor is going but nothing coming out. It has done this previously but only for a couple if minutes. Will not work at all and only just over a year old.
I suspect that the iron is clogged with mineral deposits. This happens when ordinary tap water is used - more so if your tap water is "hard". First and foremost, buy a gallon of DISTILLED water.
Cleaning it is very much like cleaning an auto drip coffee maker. Empty the iron into the sink. The first method is to pour white vinegar into the reservoir and set the iron to the hottest setting. Tip the iron flat to allow steam to escape. Press any buttons that allow blasts of steam, too. The vinegar will dissolve minerals on the inside of the iron and clogging the holes on the bottom of it. If all holes are cleared after the first time, flush DISTILLED water thru the iron. If not cleared, you can try this second method: Fill it with vinegar again and leave it sitting flat in the sink - unplugged - over night. In the morning, refill with vinegar as needed and try the first method once more. It should be clear at this point. Flush with DISTILLED water.
You can prevent this from happening again by using DISTILLED water only in the iron. There are NO minerals in DISTILLED water, which are left in the iron when water is boiled off inside it.
Jan 05, 2015 | Irons
Rowenta Iron DG-980 problem
you should have a controll or button on the iron that tells it to release the steam. make sure that the button or controll is not stuck.
Aug 03, 2008 | Rowenta DG-980 Iron
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
Jun 29, 2012 | Rowenta Perfect Iron
My stean iron leaks lot of water when steaming what can I do?
try putting iron on a higher temperature this is the way my steam iron work
May 16, 2012 | Tefal Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
Dirty water in my iron
Feb 24, 2010 | Bosch TDA8340 Iron
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
Jul 12, 2009 | Irons
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Irons Logo
81 people viewed this question
Top DeLonghi Irons Experts
Charles T Nevin
Charles T Nevin
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
