Question about Mitsubishi WS-65809 65" Rear Projection Television
Turns of after being watched for several hours.
Mitsubishi turns of periodically. We have to wait 5 to 10 minutes before it will go on again. If we try to soon, the green power light goes on for one second and then off.
  • SD Tech
    SD Tech May 11, 2010
    engage the self check this set has---when it shuts off on the front of the set press and hold both the Menu and Input buttons for 5 seconds and release both--power light will blink a two digit code 10 times; for example--1 blink, then 2 blinks is no error found; 2 blinks and 2 blinks is short protection--let me know what you find.
  • 115 Answers
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Posted on Oct 10, 2009
  • R.Delz Apr 20, 2013
    have error code 23 have a manual, dvm and iron ready to go, I have electronics background just not on projection tv's. ready to have you tell me what to do
    have manual dvm iron electronics background just not on projection tv's ready for you to tell me what to fix
4 Suggested Answers
SOURCE: mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Posted on Jan 25, 2009
Testimonial: "YES IT IS A HEAT ISSUE(IF YOU HAVING GREEN SCREEN ISSUES LEAVE THE BACK COVER OFF AND PUT A SMALL FAN BLOWING IN THE LIGHTBULB AREA.PROBLEM SOLVED"
  • 8909 Answers
SOURCE: The tv turns itself off periodically. Sometimes
I suspect a bad connection/dry joint in the power supply.
Look for regulator I/c's on heat sinks. They are favourite to get dry joints and anything that is heavy like transformers and chokes.
Posted on Oct 18, 2010
  • 98 Answers
SOURCE: My Mitsubishi TV turns on
I had the same problem with a similar tv.
the problem with mine was that one of the input components would over heat and cause it to shut off. also in your case it could be the projectors over heating or even the bulbs are starting to burn out.
i hope this helps you good luck.
Posted on Feb 28, 2011
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Mitsubishi WS-65809 65" Rear Projection Television Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
