Question about Toshiba Tecra A9-S9012X Notebook
Cant become administrator
I bought a toshiba laptop from a friend of mine and it worked fine for about 8 months and now suddenly i cant get on the web. I have tried re running the software i got with my internet provider but its saying i need to be an administrator and i havent got a password for this, and my friend has forgotten it. I have looked all through the manual and cant find anything that will help.
    Guru:
  • 597 Answers
Go to Control Panel and User Accounts. See if it will let you change the type of account you have to administrator or if you can creat an new administrator account. If that doesn't work log off and try logging on as Admin or admin (try both) and leave the password window blank. See if you can log in under admin and then change your current user account to administrator. You also don't have to run the ISP software to get on the net. You can change the settings to your network adapters manually without software. Problem here is you might have to be an administrator account to do that also.
Posted on Oct 04, 2009
The keyboard on my Toshiba laptop suddenly lost the letters T & E function. All the other keys are working. I bought the laptop from Radio Shack 9 months ago. Is there some way to solve the problem?
Nah - not much you can do. The keyboard's gone bad. Most new Toshiba laptops have a year's warranty, so you should call them and have them replace it for free.
Aug 31, 2011 | Toshiba Satellite L455D-S5976 Notebook
My P305 will not charge the battery
A friend of mine had a bad battery. I advised her to buy a new battery, which worked fine for several months. Then she called and said her laptop would not work on battery or even plugged in. I had her buy a new charger. A week later, she called and it was not working again. We tried several things (she is some distance away) and finally I had her go get the cord from her old charger (luckily the trash had not been picked up yet) and it worked fine. So even new things can go bad - it sounds like the battery charger or the cord might be at fault.
Oct 10, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
On one of my friend Toshiba Satellite L45-S2426, the sound does not play at all. Its been doing this over a month now and we're trying to figure out whats the issue is?
It seems either the sound driver has become corrupt or you have mistakenly installed any other sound driver!
Try these steps :
1. Goto Start -> Control Panel.
2. Sounds -> Playback.
3. You will see 'Speakers' in the list of devices.
4. Is there any 'Tick Mark' symbol and 'Working' message ?
5. If Yes, then the sound driver is OK. Check the other settings like, Levels, Enhancements, And Advanced options by selecting the 'Speaker Properties'.
6. After configuring, apply settings and close the window.
7. Restart your system and now check sound!
8. If the above don't works, reinstall your sound driver!
tell me if it helps...tc! :)
Jan 03, 2010 | Toshiba Satellite L45-S7423 Notebook
Display adapter fail i use a default monitor it only works 640x480 8 bit when nvidia geforge go 7600 is enabled
Looks like you have become a victim to the Video Burnout plaguing this series of notebook, I had the same issue, when Toshiba replaced the board it worked for about 3 more months then quit again. (this time outside the warranty) I'm looking for another working board to replace mine with. Good luck! it is cheaper at this point to replace the puter.
Dec 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
Hi there
This sounds like you may have a loose/broken jack on the machine. Take a small screwdriver and check to see if the jack is loose. If so, there's your problem, if not, then the problem will be in the power management system on the motherboard, and you will need to take it in for a professional diagnostics in order to track down the exact problem component.
Sep 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite M40X
try booting without the battery installed.
Apr 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop goes off
If a computer shuts itself down suddenly after 10-15 minutes it's usually down to oveheating. clean the filters and ensure that there is good airflow around the computer when you use it. you can keep an eye on temperature and control your fans with this program
http://www.almico.com/sfdownload.php
you might need to buy a laptop cooler like this
http://www.amazon.com/Targus-PA248U-Notebook-Chill-Pad/dp/B0000AKA8Y/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1204562271&sr=8-1
which sits underneath it and blows cool air in
Mar 03, 2008 | Acer Aspire 5630 Notebook
Blank screen once in a while
over heating get a labtop cooler pad 1st see if it does it agian get heat out of it 15 bucks on ebay 2500 rpm one never set it on a bed
Jan 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Crashing Laptop
if its the case of the overheating is becoming worse then
a quick fix is to go and buy one of these cans of air duster
and blast the cooling vents and heat fins
i regularly fix a toshiba lap top of a friends and the dust build up is un-real
after so long it just freezes.4359f1d.jpg the picture is inside the heat sink you can see the dust build up
here after 2 months
hope this helps you out
Nov 10, 2007 | Toshiba Satellite Laptop Cooler
Toshiba Tecra A9-S9012X Notebook Logo
225 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
