Question about Homelite Mighty Lite Lawn Trimmer
To attach recoil spring to pull cord on a
To attach recoil spring to pull cord on a homelite 26 cs
  • 551 Answers
SOURCE: Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Posted on Mar 28, 2009
  • 4 Answers
SOURCE: Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
Posted on May 25, 2009
steve_lima
  • 181 Answers
SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Posted on Jun 02, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
  • 63 Answers
SOURCE: Can not get it started.
have you tried to replace the H T lead?
Posted on Jul 24, 2010
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
Pull cord no longer recoils ... worth fixing, or get a new one?
Dealers love people like you to throw things away. It is worth fixing, you need a new recoil spring. Stephen.
Sep 24, 2010 | Homelite 30cc Piston Cylinder Kit Assy...
Pull cord will not recoil. Torsion spring seems bent but not sure of what the problem is. Thanks Milan
recoil springs are hooked on each end one locks into spool one ou tside inside hooks to rewind housing. more than likely one end broke off.sometimes can rebend but spring steel is very brittle or may have to replace spring. hope this helps
Aug 17, 2010 | Homelite Garden
Gentlemen, I have a Mighty lite Trimmer of which the cord does not recoil. It appeares that the heavy torsion spring bends when cord is pulled and cord stays out instead of recoiling. Where can I get...
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Aug 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Hello, my mighty lite 26 ss weed waker is broken. The starter cord will not retract. it stays out and I am unable to start the engine. what is the problem and how do i fix it? thank you
You will have to disassemble the unit to that point and inspect the recoil pulley (rope coils on it) and the ratchet mechanism under it and the recoil spring that draws the rope back in.
Aug 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you fit the recoil spring on a homelite 360
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem homelite then model no. hopefully this will show you correct way.
Feb 13, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Mighty Lite Lawn Trimmer  Logo
773 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
