Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
As I close my garage door, I like to leave it open about a foot. I used to be able to stop it with my remote, but now I have to push the remote repeatedly to get it to stop. I have checked the batteries and these are new remotes with a new opener. This used to be an easy task and now it it very frustrating to complete this task. What's up????
    President:
  • 3,197 Answers
Newer openers have always been designed to reverse to the open position when a button is pressed during closing. This is a safety feature. To do what you want you must press the button while the door is opening. That will stop it where you want.
Posted on Oct 04, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
I have liftmaster door opener 41a5021-1d. Using the remote door closes only half way. how can I repair this problem?
When the motor stops in the down position, pull the emergency release handle. Push the door fully closed by hand then engage the emergency handle. Open the door with the remote and then close it with the remote to make sure the door closes completely.
Oct 10, 2014 | Building Materials
How do you stop the door leaving a foot open at the bottom?
To stop the door in a partially open position, the button on the wall switch or remote should be pulsed when the door is opening from the fully closed position.
Jul 12, 2014 | liftmaster Garage Door 1/2 Hp
Wanye dalton door opener modal 3018. goes up 1 foot and stops
Check your door springs. Usually just over the door and can be seen when the door is closed. A broken spring is the most common cause of this problem.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
Door goes up about a foot and stops
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
50 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
