Question about GE Washing Machines
My GE washer, # WJRE5500g0WW, makes a noise in the outer drum
I tried to trouble shoot this problem on GE's website, but they don't recognize this as one of there models. Go figure!
The inner drum moves just fine, but the outer drum makes a terrible noise.
sdmc73
  • 121 Answers
SOURCE: Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Posted on Dec 02, 2008
  • 135 Answers
SOURCE: CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Hope your problem was solved.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • 14 Answers
SOURCE: Duet GHW9150P inner SS drum is actually loose but
go buy new washer the drum bearings have gone and it really is not worth repairing . it can be repaired but always found that it never lasts long once done.
Posted on Jul 07, 2009
beltronic205
  • 1474 Answers
SOURCE: loud noise during spin
Sounds like drum bearings gone..Quite expesive repair
Posted on Oct 03, 2009
  • 104 Answers
SOURCE: Bra wire stuck between inner and outer drum how to
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Posted on Jan 28, 2010
I have a frigidaide Gallery washer .I think it might be 2003 model.Trouble is while the washer went into its last rince cycle.The drum dropped and stopped dead. I heard the machine make a wierd noise.I...
there is a chance the inner tub has become lodge to the outer tub.this is a very expensive. check with the manufacture and see if the tubs are still covered by a warranty but i don think so
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
WHEN SPINING MAKING A LOAD NOISE
your drum bearings have gotten water in them from the lip-seal on the drum drive shaft,you need to remove the rear access panel,remove the belt remove the pulley,then remove inner tub and remove the spider that holds the inner drum on,then remove old seal and replace the inner and outer bearings,dont do just the inner bearing as the outer one isn't that expensive and may go out later,and its very labor intensive,anywhere from 2 to 7 hours depending on how stuck the old bearings are in the machine
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer's drum is not moving at all.
a worn out or broken drive belt perhaps?
Check your appliances parts diagram to see what it uses
to connect the motor to the drum.
I didnt find your model online so look here and see if you recognize one of these units.
http://laundry.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_washer_product_list.html
Mar 15, 2010 | GE Washing Machines
My Amana LW4303W washing made a loud bang noise,
Hi.
You have broken the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Here all parts and diagrams for your model.
Regards,
Nov 14, 2009 | Washing Machines
I have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open...
Normally water on the floor can be from a few places. Mostly a faulty drain pump: possibly a tear in one of the pipes: rust in the drum: possibly water in the centre which comes from the bearings.(if the machine makes a racket when spinning, then i would look at the spin bearing collum). even concider drain pipe at outlet not running out onto floor. Either tilt washer back about 45 deg. to look underneath or possibly remove panel to allow a visual of the motor and components. See if you can pick up any indecationof water having run down from a particular spot. If so rectify. Hope it helped. .Ge washers not farmiliar to me but most problems are similar.
Sep 17, 2009 | GE WJSR2070B Top Load Washer
Won't spin
Take the front panel off by using a putty knife to push in on the two clips at the top edge of the front panel. Now, pull the thin tube off from the left front side of the outer tub. Cut off about 1.5 inches of it and replace. Test. This tube tends to plug up right there. It's really best to just clean it out, as if the problem reoccurs, you will soon run out of tubing. I usually see this problem with machines which rarely, if ever, see regular liquid bleach used. To prevent this from happening again, fill machine to the lowest water level, using the hot water, and several cups of bleach (no clothes) and run a cycle through a couple times a year. Make sure to rinse machine before using with clothes again.
May 30, 2009 | GE Washing Machines
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Washer problems
Hi there!
The problem is probably the main drum bearing at the back.
Isolate power and water supplies.
The top will have to come off,(screws along top edge at back), then the motor mount slackened to remove the belt. Then try rotating the drum by hand, If the noise is still there, check for any items lodged between metal drum, and the outer plastic wash tub. If everything is clear, The noise will be from the rear bearing, which needs to be replaced.
I can assist you further with this.
Jun 19, 2008 | Zanussi ZWF1430W Front Load Washer
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Drum bearings
as per soultion 2 this is a hard drawn out job involving a lot work and there is no guarantee the bearings will not shatter when trying to knock them out. better get someone in!
May 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
