Leaks lime looking oil
Ge 7 cycle 2 speed top load washer model # wwa 8829 i think leaks out the bottom with a oil substance lime in color
  • 51 Answers
The problem is the bottom transmission seal. This can be fixed with a few basic tools without calling a tech. Lay the washer on it's back, block up the tranny support and remove the pulley and seal. you might want to consider changing the belt and lower transmission bearing also. Total price of these parts should be around $50. Don't worry about the loose of oil.
Posted on Dec 23, 2007
Oil leak found under washer. Cannot tell where this is coming from or what cycle. Washing machine still seems to be working okay.
the most likely cause if the oil looks like motor oil that you put in your car but only thicker,is that it is leaking from the transmission which is very common in ge washers the oil is in the transmission to lube the gears which make the machine agitate
to be sure you could remove the front panel and would see alot of oil in the base frame
to remove the panel place a screwdriver between the panel and top and feel around and find 2 clips (one on each side) press on those clips while pulling the panel out
Jul 19, 2011 | GE WBSR3140DW Top Load Washer
GE Washer Mod # WJSE4150 click on spin cycle when fisrt engaging, seems to run & spin fine when in second/hiher speed.
Hi, since your washer is a "belt" drive, I'd suggest checking to see if perhaps the belt is slipping. While you're checking that, make a note of "oil" sprayed around the cabinet on the belt, pulley's etc. These generation GE units are known for tranny leakage/failures. If you're able to remove the front panel from the cabinet, you'll get a much more thorough look at your drive & basket/tub assembly. Just push in the 2 clips on top of the front panel on both sides with a puddy knife or narrow flat screw driver, and pull forward. The bottom just hinges on 2 hangers and the front comes right off. That's a start for now, hope it's a help. Let me know. Good Luck :)
Oct 28, 2009 | GE WJSE4150B Top Load Washer
GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Aug 20, 2009 | GE Washing Machines
My Whirlpool washer LA768M leaks water during the cycle.
Hi, it does sound like a pump but, you should not have oil with it. Tip the washer back against the wall and look underneath to see if there is transmission fluid/oil leaking.
Please let me know and I can assist you with changing the pump.
May 18, 2009 | Whirlpool LSB6200KQ Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
293 people viewed this question
Top Washing Machines Experts
