Question about Kitchen Appliances - Others
I bought a lamp off ebay and when I plugged it into my wall it blew the circuit in the room twice. I used an appropriate light bulb so what else could it be?
    President:
  • 1,723 Answers
The wires in the lamp socket are touching the metal lamp base. Remove the socket and tape over the wires or reconnect as needed.You will see the black spot where it blew.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 04, 2009
How to replace the lamp for Panasonic projector
If you bought a lamp from eBay then its most likely not a real brand bulb. The PT-AE1000 uses an ET-LAE1000 lamp that should have an Osram, Philips or Matsushita brand bulb. If you do not see PVIP, M or UHP on the bulb then its most likely your problem. Cheap lamps are not worth the money. They fail early and end up costing you more money in the long run. Panasonic Projector Lamp
These folks sell lamps that always work. I would return the eBay lamp and buy one that will work. Their support and customer service are one of the best in the industry.
Aug 11, 2015 | Panasonic PT-AE1000E Projector Lamp...
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
My TV made a noise that sounded like a "pop" when i pushed the power button to turn it on. Then my lamp light came on and stayed on. I unplugged it from the wall outlet and then plugged it back...
The tv old projection lamp in the tv now like 1 1/2 or 2 yeears?The tv LED "LAMP" light up or flashes the projection lamp is dead.Yes,the tv require a new projection lamp.
Oct 31, 2010 | Mitsubishi WD-60735 Projection Television
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
SCREEN SUDDENLY WENT DIM
One of 2 things happened....
1) You Blew the Power Inverter... The Power inverter is a thin rectangular circuit board that plugs into the display panel cable and also powers the LCD Bulb.. If This Part Fails - You Lose Light to the Display even though the display will still be on and viewable against a bright light....
2) The LCD Bulb is Faulty... When the LCD Bulb Fails it will typically give pre-warning signs- though not always.... It will give signs like the whole screen has a light orange or pinkish tone to it, but eventually it will blow and no light at all to the Display Panel....
Both Of These Are Repairable....
The Power Inverter Can Be Purchased Off of Ebay, For Around $15 to $30
The LCD Bulb Itself is also Replaceable.. Though It is a Job Only to Be Performed By An Experienced Laptop Tech... Bulbs as well can be bought off of ebay for a few bucks..
Feb 13, 2009 | IBM ThinkPad T30 Notebook
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Kitchen Appliances - Others Logo
75 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
