Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Smeg Oven blowing
Smeg oven keeps blowing
  • 1 more comment
  • 14wishy Oct 14, 2008
    My Smeg A2-2 has died totally. It did not trip the 32amp CB in the fuse box but there is no electrical activity, ie no display no ignition no lights! Typically the warranty has just ran out by weeks, any suggestions welcome
  • jasbutter Mar 04, 2009
    What is a TOD.
    My cooker only cuts off when dial is turned clockwise.
  • DavidAF Mar 05, 2009
    I have the same problem, it looks like anything to do with the fan pops the breaker. Does anyone know if this is 'diy' fixable without having to call out an expensive engineer? I inherited this oven and the warranty ran out last week!!!!
    Sergeant:
  • 409 Answers
Do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Posted on Sep 13, 2008
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
The fan only blows cold air and does not heat up any food.
Jun 13, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven not working - fuse blown
Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
Plz rate this solution.
Thanks
Dec 14, 2008 | Smeg Ovens
My smeg oven,(bottom fan oven) keeps getting hotter and hotter till it cuts out or the fuse blows when i switch it on no matter what temp i put it on,iam assuming its the thermostat,were is it and how yo...
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Dec 12, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Oven blowing
If the stove is vented to the outside, it may be just drawing air from the room through the fan.
Oct 14, 2008 | Smeg A2.2 Gas Kitchen Range
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
385 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
