Question about Pacific Digital MF-810SW Digital Picture Frame
Back lighthing does not work after a household power failure. I appears that there is an RF voltage at the connector to the backlight, but it is not lighting up. When checking it I got a high frequency arc in the connector on the circuit board. There is a picture, but not backlit.
  • 58 Answers
Sounds like the bulb is blown, a good case to get surge protectors next time.
Posted on Oct 04, 2009
I'm probably a little late to help you, but I have had this issue a number of times on three different frames. It has always been the power supply - the output capacitors are underpowered for the application, thus are easily damaged. Use a meter to test the output of the supply. If good, it will be a solid 12VDC. I ordered the first few replacements from Pacific Digital, but later opted for a third-party supply.
Posted on Sep 20, 2010
Model FGMV174KFB everything works but food doesn't heat up?
Could be an open internal fuse, failure of the door interlock or control panel failure. Add magnetron failure as another possibility.
Sep 25, 2017 | Microwave Ovens
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Why does my ,hp lc4776n, screen come in and out
hello,,,open the back cover of your tv check the power supply section .to identify the power supply section ,it is the pcboard where the ac main supply is connected..there is a connector there that is connected to tha cpu board....resolder the terminal of the connector and tighten the connectors same to the other end..2nd the supply of the inverter board..resolder the terminals and tighten the connectors...the inverter board is the board where the backlights are connected .power supply of the backlights...be carefull it is a high voltage section..its input voltage is from 12vdc - 24 vdc.output is 300 up vac...back light is the bulbs that illuminates the screen of the tv...when it is busted your screen will appear black..
good luck hope this helps you...
please rate my help tnx.
May 29, 2010 | HP LC4776N 47 in. LCD HDTV
Sound with no picture..backlight working
This failure could be due to a backlight inverter board or the power supply is not providing the 24 volts to it.
The way to fix it is by measuring the voltages from the power supply to the backlight inverter board, if the voltage is present then the backlight inverter board is defective and will need to be replace. If the voltage is lower then 20 volts, then is a power supply failure.
Click here to find the backlight inverter board.
Let me know if you need further assistance. I repair power supplies for all LCD models.
Jul 24, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Want hold a charge
get a test light and a schematic. unplug stator plug.start bike ,make sure battery has full charge. test each pin on connector that is attatched to the 3 yellow wires.should light on each pin. if all good check for burn marks around connectors, front & back sides, and on wires. if no power on yellow wires, stator problem. if power, plug connector together, now test for voltage in wires on the voltage regulator side of the connector, to see if the voltage is making it through the connector.if there is power to volt. regulator,test w/ multi meter across battery leads to see if there is charging voltage to battery,approximately 13-15 volts. if only battery voltage(12.2 or less) while bike is running,voltage regulator is no good.if charging good, but bike wont start after prolonged sitting(say overnight) a system amp draw test is needed to see if something is staying powered up while bike is not running, drawing down battery.
Feb 18, 2009 | 1994 Suzuki RF 900 R
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Pacific Digital MF-810SW Digital Picture Frame Logo
120 people viewed this question
Top Pacific Digital Photography Experts
Tony
Are you a Pacific Digital Photography Expert? Answer questions, earn points and help others
