Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
SMEG A 2.5 Range Oven
This is a SMEG a2.5 100cm range cooker purchased 4 years ago. Oven blew last night (Main Oven). Reset circuit breaker and switched socket on , then on opening oven door , oven blew circuit again ? This happens every time.
  • Anonymous Jul 19, 2008
    I have a Smeg A2 (Type 2DA) oven and when either of the ovens are turned on the consumer unit trips the electricity. When I have been able to get the oven to turn on the it fails to heat up. Do I need to just replace the heating element ?
  • Anonymous Mar 04, 2009
    What is a TOD?
    MY cooker on stops if dial is turned clockwise.
    Sergeant:
  • 415 Answers
Sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
A week ago our oven stopped working during cooking. I had my husband flip the circuit breaker and it still didn't work. 15 minutes later we were able to get it to work again. Today i started to preheat...
Had similar problem with my oven.
Turn off the breaker to the oven/range and remove the panel which exposes the controls. You will probably find a burned spot on the pc board.
Mine was where a spade lug plugged a wire to the board and caused by a loose connector at that lug. I hard wired/soldered the wire to the board (new board was $200+) and the repair lasted several years.
Sep 19, 2017 | Jenn-Air JES9800BAS Electric Kitchen Range
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Problems with the oven heating up on Smeg CC92 MFX5 range cooker
instalation wiring may be criss crossed if under warranty get them out to fix it.
Oct 13, 2009 | Kitchen Ranges
My Jenn-air 2 year old oven and top stop working any help? please...
Hi
If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg Oven blowing
do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Sep 09, 2007 | Kitchen Ranges
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
549 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
