Question about Canon MultiPASS F60 All-In-One InkJet Printer
Wrong cartridge alarm on cannon F30
My cannon f30 has alarm blinking and it says wrong cartidge, but it is not the wrong cartridge. what do i do to resolve this??
4 Suggested Answers
  • 2692 Answers
SOURCE: WRONG INK CARTRIDGE CANNON MP730
OK, thanks.
Posted on Mar 11, 2009
  • 385 Answers
SOURCE: canon multipass 550 will only scan
The printhead is faulty and needs to be replaced!Good Luck!
Posted on Apr 29, 2010
  • 11800 Answers
SOURCE: Wrong cartridge is appearing on
If the message appears even with new cartridges it means that either the connection between the smart chip on the cartridges and the printer's processor is not functioning properly or the processor itself is faulty. This connection passes thru 4 mechanical connectors: cartridges - print head and printhead - carrier thru pin array, carrier - data cable and data cable - mainboard thru ribbon cable connector.
To find out which you must clean and check all the connectors. The first 2 are easy - just remove the cartridges and the print head and clean them: the contact plate with a rubber eraser, the pin array with a q-tip soaked in rubbing alcohol. For the second 2 you will have to dismantle the printer and access the carrier, take out the ribbon cable out at both ends, inspect it for breaks, clean the contacts with a rubber and reattach it firmly. If after all of that you still get the error then the processor is faulty and the printer is dead - replacing the processor would cost more than a new one.
Posted on Dec 31, 2010
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
"wrong cartridge" message appears, new
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
I found a reset sequence for a MP730 printer in this website that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Feb 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
This works on the F30, F60, and F80.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Alarm is blinking with message "waste ink near full" - What do I do???
All the best
Oct 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Waste ink cartridge full
Maybe it waste ink
Jan 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Wrong Cartridge Error Message
I have same problem.Please let me know if u find an anser
Feb 10, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
19 people viewed this question
old marine
old marine
