Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
There is suction when we have the filter basket off but when it is attatched there is no suction
  • 13 Answers
The filter tube is clogged , I know it takes time but use either damp rag over filter holes or try blowing into holes I find gently tapping and blowing help also swifter dusting cloth helps unclog it
Posted on Oct 04, 2009
Hoover linx handheld losing suction
please go to web page from Hoover and see the videos respectively from your model, etc.
http://hoover.com/support/video-instruction-guides/
However this can be a problem:There could be a clog in the hose or the bag/tank may be full and need to be replaced or emptied. Also, check the belt to see if it is worn or broken, if it's defective replace it.7_28_2012_10_15_39_am.jpg
Jul 27, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
Ive completely lost suction from the main part of the machine. I can only use the hand held attatchments attatched to the nozzle
Sorry to hear you're having problem with your DC07. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-SY
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Apr 27, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not picking stuff up and no suction in hose as well, suction sounds good until you go to vaccuum floor
Because this unit is bagless there are more gaskets to seal the suction portion of the vac. you are most likely missing a seal, can you remove the basket and place your hand near the suction on the vacuum? it is shielded so you wont lose fingers. if there is suction there, look at the bottom of the basket for a gasket, same for the top
Jan 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dirt is picking up but not going in to the dirt cup
Hi there SmartAlec from NelsonVacuums.com.au here. Sounds like an obstruction to me (ie a blockage somewhere). Start by taking off the hose and testing to see if you have suction where the hose attatches. If you do have suction put the hose back on and feel it as if you are going to vacuum the couch, if you have lost suction you must have an obstruction in the hose which has to be removed. The other likely place to look is under the machine behind the brush.
Hope this helps - Happy Vacuuming ! :)
If not send me a message and ill try and help you further!.
Aug 26, 2009 | Bissell Vacuums
No Suction + loud Noise
motor is probably is full of dust or needs replacing
May 11, 2009 | Vacuums
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hair gets stuck in upper filter basket instead of going into the lower basket that you are supposed to empty. It is a Bissell 37604 Lift-Off Revolution Pet Bagless Upright Vacuum Cleaner
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
Apr 19, 2008 | Vacuums
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Furniture attatchment
On the attacment there is a slide move slide either up or down for brush to rotate.
Mar 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
103 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
