Question about Maytag Neptune MDE5500AY Electric Dryer
Series 9 heavy duty dryer
I have wirlpool dryer heavy duty one there is no air coming through the vent at the back looks like ist bloked is there any other filter I should clean apart one in the dryer inside - cleaned after each use ? please advise thanks alicja
  • 619 Answers
The blower does not work , open at back of the machine, test continuity of the blower motor if open need to replace.
Posted on Jan 01, 2008
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
I have a Kenmore 80 series heavy duty dryer that is not giving out much heat.What should I be looking for to solve the problem?
Is it gas or electrric? Either one i would check the dryer vent hoses. Check the lint trap as well. The lint trp is the exit for the hot air to circulate. Sometimes if clogged with lint these dryers could go either way they could over heat and cause a fire or cause the element or thermostat to fail. The electric dryers have a thermostat and a heating element. Those tend to go bad. Back panel should be taken off and unplug unit check.
Apr 03, 2011 | Kenmore Dryers
Maytag Dependable Care Plus/Heavy Duty Dryer Model # LDG9304AAM Dryer is turning, there is heat but clothes are not drying
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Sep 24, 2010 | Maytag Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Kenmore heavy duty 70 Series Electric Dryer
If you are using Fabric Softener Sheets than look in the dryer closely for one to be wedged in a fin or anywhere inside .They will make the streaks you mention. Please rate this !!!
Jul 03, 2008 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
102 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
