Question about Garmin Quest GPS Receiver
Losse antena loose anten ie flip up antena wont saty in place and looses signal
  • 24 Answers
Did you purchase this unit new? If not, someone may have taken the unit apart and lost a small spring out of the antenna assembly. If you place the unit, display side down, with the antenna hinge away from you, there are two small phillips head screws on the right side. If you remove these screws, a small plastic endcap for the antenna assembly will come loose and the antenna can be removed. Where the endcap and the antenna are hinged together, there should be a small spring that puts tension on the antenna. If the spring is missing, the antenna will not remain in position.
Posted on Jan 23, 2010
What could a loud clunk noise be when starting my truck
Could be Big End in Engine or a Loose Generator, etc, (ie) or anything attached to engine that may have come loose
Feb 06, 2016 | Cars & Trucks
We have to retune 2to3times per day
the cable to the recorder could be broken causing it to loose signal,
bad antena i know alot of people around my area having the same issue.
Mar 11, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
My g1 loses service every single night for sometimes up to 3 hours, despite however many times i turn it off and back on. still doesn't work.
its internal inbuilt antena is loose show it to service center for setting internal antena properly not loose like urs
Mar 22, 2010 | HTC G1 Smartphone
Loosing GPS signal on a E120, also have 2-E80's on same boat, and they too loose signal
1. All your E Series MUST HAVE the same Software 5.23
2 You must set the Divice where the GPS Signal comes in as MASTER
all the other Repeater
3. Your GPS antena shoud be mounted outside
Sep 16, 2009 | Raymarine E120 GPS Receiver
Our tv worked fine last night and now at first it was really dark and now it is flipping. What do I do?
The loss of brightness is probably caused by degraded high-voltage internal to the set. This can be caused by an electrical "brownout" that will correct itself.
The flipping problem is due to a degraded vertical synchronization signal. First make sure you have a strong signal - no loose antenna/cable connections, etc. Assuming you have a strong signal (i.e., no "snow"), analog TVs sometimes have a so-called "secondary control" (labelled "Vertical Hold", "VH", "Vert", etc.)located on the rear of the set. If you are lucky you may have one and be able to adjust it and regain stability.
Old sets used analog components (which age with time and are somewhat heat-sensitive) to control the vertical sync. Modern TVs use digital signal processing techniques that need no such controls.
Probably need to take the set to a repairman, if you can find one.
Aug 25, 2009 | Televison & Video
Tv says no signal being received
check your cable or antena system
if its ok then chek the antena(RF socket).
for brocken or loose contact,
if thats also ok
check or replace your TV TUNER Unit.
by serviceing professionls.
Oct 20, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
No signal
out of area where no signal can be reached
or you droped your phone to many times and jared the antena connection inside loose
May 09, 2008 | Motorola Mobility RAZR V3
Loss of signal after about 10 minn of time
If it happens around the same suburb the sattelite can't get to that area.
Or it is programmed for another location meaning : it wont display most of the places near you.
Or if its old it wasn't programmed with all the streets as new streets do get built alot.
Also this GPS is a pretty bad one as I am already dealing with 5 others They are all 660s and are the only GPS with problems.
Hope this helps - Josh
Jan 30, 2008 | Garmin Nuvi 660 GPS Receiver
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Garmin Quest GPS Receiver Logo
133 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
