I AM RECEIVING E20 MESSAGE.. WHERE IS THE FILTER
I AM RECEIVING E20 MESSAGE.. WHERE IS THE FILTER LOCATED AND HOW DO I CLEAN/CHANGE IT
  • 909 Answers
The filter is normally on the front, either behind a flap or the "kick" panel
Posted on Oct 04, 2009
Wat is code for e20 on a ewf 1080
E20 error code measn blocked filter. Removing the blocked filter you have to remove the water from inside by using the small flexible tube which located next to the filter at the right bottom of the machine. Then the only think it still remains was to unscrew and clear the filter.
Hope helps.
Apr 22, 2011 | Electrolux Washing Machines
Getting E20 error message so I need to clean out the pump and hose but I can't get inside the machine - how do I get access to the pump? Thanks
Try bottom right / drawer here Filter within, you will see a long tube that comes out ,you take out the end stopper and drain first then remove and /clean filter good luck...
Apr 01, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My Zanussi ZWF1658W washing mashine will not spin and drain the water it has a E20 error message on the display
I believe E20 is a blocked filter.
There should be a small door on the front of the machine almost at floor level.
BECAUSE THE MACHINE IS, I PRESUME FULL..... do this:
Unplug from mains
Tip machine backwards at about 45% so the water is not going to come gushing out of the filter when you remove it
Open the little door
remove and clean the filter
replace it
close door
put machine flat on floor agin
plug back in
start a cycle
Pray
Feb 26, 2011 | Washing Machines
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
E20 message I get on my washer machine
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Apr 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Dec 02, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
