Question about Garden
How do I remove the sliding panel to check the rolling wheels? the front wheel has collapsed, or something. It drags badly and have to lift the front end to engage the latch when closing. I tried to lift the door up to clear the lower track but it didn't seem to go high enough to clear the lower track to swing the bottom of the door out and remove.
    Guru:
  • 597 Answers
You have this listed under chainsaws. To date I've not seen a chainsaw with rolling wheels. Most he ones I've seen you have to pick them up to pack them. I've seen none with sliding panels, lower tracks or doors.
Posted on Oct 04, 2009
HOW TO FIX MY 2007 IMPALA AFTER SLAMMING BRAKES IT WONT MOVE IN DRIVE
Jack up 1 tire at a time and see if a wheel is stuck. Make sure you do this on a level surface and you block the back wheels when you lift either of the front tires. I am guessing but a calliper is prob jammed but could be a bad wheel bearing collapsed or something else binding in the front drive train.
Nov 19, 2014 | 2007 Chevrolet Impala LS Sedan New Cars
Wat parts do i need
Start off with the cheapest first if you're not sure what it is.
Check the wheel hub bearings (inner AND outer)
Jun 03, 2013 | Cars & Trucks
2000 chevy astro wheel bearings
jack it up, pull the calipers and check them.
Feb 14, 2018 | 2000 Chevrolet Astro
What to look for as I remove the rear wheel. Shaft Drive
Center stand the bike or lift the rear wheel off the ground, loosen the rear axle nut, take out the axle bolt, knock out the spacer, unscrew the rear brake adjuster nut, unbolt the rear brake panel stop arm, grab the wheel, and slide it sideways away from the final drive. The wheel should slide right off the spline of the final drive and roll out the back under the fender. If the wheel won't slide past the final drive let the air out of the tire. Be sure to coat the spline of the final drive with moly60 paste from your local Honda dealer when reassembling.
Mar 02, 2011 | 2005 Honda VT 1100 C Shadow Spirit
How to change the back brakes
Center stand the bike, remove the rear drive axle nut and bolt , take out the spacer, spin the nut off the brake cable , and unbolt the long brake panel stopper bar at the brake panel . Now you should be able to slide the panel out of the wheel and remove it. If there is not enough room to remove the panel , push it back in to the wheel and grab the whole wheel sliding it off the final drive spline. Now roll the wheel back far enough to pull the brake panel out of the wheel and replace the shoes . Be sure to regrease the final drive spline with MOLY60 grease available at the Honda dealer before sliding the wheel back on.
Aug 17, 2010 | 1984 Honda VF 750 S
How to change rear tire on 2004 750 honda shadow aero? Do i need to pull the final Drive?
You do not have to remove the final drive , the wheel is resting on a spline shaft. Center stand the motorcycle or lift the rear wheel, remove the axle bolt, knock out the spacer, and slide the brake panel out of the way. Now the wheel is resting only on a splined shaft. Grab the wheel and gently slide it away from the final drive ( off the splined shaft ) and roll it out the back of the wheel well. When replacing the wheel be sure to get some MOLY60 paste from the Honda dealer and grease the spline before putting the wheel back on.
Jul 29, 2010 | 2005 Honda VT 750 Shadow Aero
How to remove front tire on 2003 harley flhtcui
To remove the front tire, you'll need something to lift the bike with like a frame jack. Position the jack under the bike and lift it slighty but not completely off the ground. Make sure the bike is stable and will not fall.
Lift the bike until the weight is off the front wheel but the wheel is not off of the ground. Loosen and remove the axle nut and loosen the two bolts on the bottom of the fork slider on one side. Slide the axle out of the wheel.
Now, carefully continue to lift the bike until you can get the wheel out from under the front fender. Make sure that you mark or can remember where any spacers go and in what direction they face on the axle.
Feb 17, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
1997 1500 4x4 pulls to the right
Sounds like a brake caliper hanging up. Check the slides to see that they're smooth working. Jack the right side up & make sure the front wheel turns fairly easy. If it's dragging alot then the caliper slide is fubar or the brake hose is collapsed internaly. Replace the hose if that's the case.
Aug 04, 2009 | 1997 Dodge Ram 3500 Club Cab
How do i remove the rear wheel on a 2005 harley davidson dyna wide glide? the exhaust won't come off and is n the way. not sure how hard the springs r 2 remove and put back on. The bike is on an air lift.
you should not have to remove shocks dont do that to remove wheel loosen the back section of your exhaust the nut that holds it is the only one you need to take off the back section of your exhaust now loosen the tension screws in front of the axle nut on both sides this creates slack on your belt or chain drive take off big nut on axle use tools on both sides at same time to keep axle from spinning take weight off of wheel just enough to allow wheel to be wiggled and slide the axle out you can tapp on axle just not on threads if you have to beat on it place nut on axle loosly and hit only to free it up it should slide out after a few taps the brakes are on a spacer style format on axle rememmeber with spacer goes on which side they are different in size to accomadate wheel spacing to brakes and belt alignment when wheel drops remove drive type belt or chain wheel should roll out of place you may need to lift bike higher with lift or jack to clear fender on roll out ta dah you have your wheel off to put back on reverse this order i change all my own tires have done all types for friends i hope this helped you
Jun 10, 2009 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
Sluggish accleration
SOUNDS LIKE THE BRAKES ARE NOT RELEASING IN THE REAR IF WHAT YOU SAY ABOUT THE PARKING BRAKE IS CORRECT. JACK UP THE REAR OF THE TRUCK AFTER CHOCKING THE FRONT WHEELS AND SUPPORT IT WITH JACK STANDS. AFTER THIS, TURN THE KEY IN THE ON POSITION WITHOUT STARTING AND PUT THE TRUCK IN NEUTRAL. TRY TURNING THE REAR WHEELS. IF THEY BOTH TURN FREELY, THEN CHECK THE FRONT WHEELS. IF THE WHEELS DON'T TURN THEN THE HOSES MAY BE COLLAPSED ON THE INSIDE OR THE CALIPERS ARE FROZEN. HOPE THIS HELPS. KEEP ME POSTED PLEASE. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA.
May 10, 2009 | 2000 GMC Jimmy
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
