Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi projection tv model# VS-5078 picture went out but I ca
Mitsubishi projection only gets a blue screen I can still hear the sound and all the bulbs are still good.
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Posted on Jul 31, 2007
  • 4 Answers
SOURCE: need help repairing Mitsubishi VS 4541 rear projection TV
I have the same type of TV, and I think it has a filed "power rail", as the LED does not burn at all, nor do the heaters of any of the CRT's. When I plug it in, I can hear the relays click in, and hitting the power button will cause the relays to click. Other than this, there is no sign of life from this TV. I really would like to find a repair manual or a schematic to aid in troubleshooting. The self-diag trick may be handy if the LED would come on. I'll try it and see what it does.
Posted on Sep 09, 2007
SOURCE: Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
Posted on Nov 20, 2007
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS 45609 Blue Shadow On TV Picture
you need to replace the convergence IC STK393-110 you can get it as well as picture installation instructions as well as free online tech support at the link I posted very good prices
May 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Oct 06, 2006 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
