Question about Pelonis Heating & Cooling
The automatic thermostat isn't working. The heater doesn't stop at all anymore. What can I do?
    President:
  • 1,714 Answers
The fan switch has failed and keeps the blower running. Change the fan switch.
Posted on Oct 04, 2009
Washing cycle stops
Thermostat or heater faulty. Can get over temporarily by connecting fill hose to hot tap only but then doesn't allow cool rinses!. Check thermostat continuity and power to heater to trace faulty part
May 09, 2012 | Washing Machines
Heater stop working. blower still works no heat.
check the coolant level in the rad,then check both heater hoses when the truck is warmed up they should be the same temperature if not then the heater core is plugged.you can try running/soaking the heater core with CLR to try to unplug it.if it doesn`t work then it will have to be replaced.also the thermostat may need replacing.
Oct 27, 2011 | 1994 Toyota Pickup
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Amana ARB9058CSO defrost system isn't working. I tested the timer and it seems fine. When in defrost mode there is 120V at the heater but no heat is generated, so i assume the heater is dead but can...
that's a calrod heater,they hardly ever go bad but it could be bad,try this,it's a good idea to change out the thermostat to while you're in there so do this,shut down the freezer control or unplug the machine,cut the two wires going to the thermostat located on top of the evap coil,wire the two wires together bypassing the thermostat,plug it in and put it in defrost,if the heater gets hot then you know the t-stat was bad and the heater is good,if it's in defrost and the heater doesn't get hot change out the heater and the t-stat and you shouldn't have to worry about either one of them going bad a gain.,also you can look at the t-stat,if it has clear plastic cap on top and it looks popped up on one side,it's bad,you can tell just by looking at the t-stat.hope this helps,when you cut the wires off of the t-stat cut them as close as you can to it so you can connect the new t-stat to the wires,when you get the new one the wire connectors come with the thermostat
May 18, 2011 | Amana ARB9058C Bottom Freezer Refrigerator
Pilot is lit but the heater won't fire up
A few things dictate when the main burner turns on. One is a thermocouple not getting hot enough, the other is a bad thermostat ot thermostat wire, and another is the gas valve. First look at the gas valve located on the heater and make sure it is in the On position and not in the Pilot position. Remove your thermostat and jump the two wires together. The heater should light. If not, go back to the gas valve and find the wires up to the thermostat, the should be attached to terminals marked TH and MV or something similar. Jump the terminals. The heater should start. If not, you may need to replace the thermocouple.
Sep 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Replace cooling fan termstat and vehicle still over heats
Thermostat
Test thermostat in a jug and pour boiling water on it , it should compress meaning it works. Check that the waterpunp is operating pushing water into the engine .Check that radiator water flows to the watrpump. Is tension of fanbelt of waterpump sufficient that it doenst slip. Lastly check that the radiator fan is working if has a electric fan. if this doesn’t help check if radiator or engine water passages isn’t blocked.
Aug 29, 2009 | 1995 Pontiac Sunfire
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Heating & Cooling Logo
226 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
