Question about Steam Fast SF-450 Iron
My Steam Fast SF-450 Iron produces steam and then sometimes it does not. The hose continues to get hot, but again no steam. I've tried cleaning it multiple times, bet yet still have problems with steam coming out. I've tried researching a manual on-line, but there are none. Please let me know if this is something that can be repaired or if it's time to buy another. Thank you. Crystal
5 Suggested Answers
SOURCE: parts
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Posted on Aug 19, 2008
SOURCE: Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Posted on Dec 09, 2008
  • 2501 Answers
SOURCE: I cleaned my fastpress steam
It could be that when you were cleaning out the tank, some of the sludge got stuck in the outlet pipe.
Try cleaing it again (giving it a good jiggle about) and try again.
If this doesn't work, try using and iron cleaner.
My initial assumption was that there was some water flow before you cleaned the iron, is that the case?
My experience with coffee machines and steam irons (fundamentally the same device) is that if cleaning is left too long (and there is no water flow), then the pipes can get terminally clogged, as some flow is essential to allow cleaners to penetrate the pipework.
Good luck
Posted on Sep 19, 2010
jyackle5
  • 8197 Answers
SOURCE: Need instructions for Steam Fast SF-450
You can get the manual on the link below.
http://www.topinnovations.com/steamfast/archived/SF-450/pdf/SF-450_Manual.pdf
Posted on May 27, 2011
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Tefal easycord gv 5140 no steam
do this. and use the common sense and KEEP the calm. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 24, 2012 | Rowenta Irons
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Parts
Jul 05, 2008 | Steam Fast SF-450 Iron
Steam Fast SF 680 arm is hanging up
Top Innovations, Inc.
6655 Troost Ave.,
Kansas City, MO 64131
Dec 27, 2007 | Steam Fast SF-680 Iron with Auto Shut-off
Steam Fast SF-450 Iron Logo
70 people viewed this question
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
