Question about Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive
Dell Inspiron 1150 Wont Start Up
When i click the power button, (with or without the power cable) the laptop goes to start up, you can hear it 'kick into gear' the caps lock light flashes five or six times then it dies, does anyone known what this means? do i need a new one?
  • jaydell Jun 11, 2008
    Same problem! After I press the power button, the laptop seems to be starting up (the screen remains totally black) but after the caps lock light flashes a few times, the laptop shuts down!
    Please help!!
  • da31-10114 May 15, 2009
    same problem with caps lock flashing approx 10 times, then machine shuts down. Tried removing memory, swapping around memory, on battery power and on mains power. No joy I'm afraid. Best off flogging it on ebay for spares as the cost of motherboard is more than the machine is worth!!
My niece had the same problem with her Inspiron 1150, after investigation it appears the power jack is the culprit. replacement is around $40.00 form
Posted on Jul 16, 2008
Posted by Virgill, on May 30 2008
Hi, my Dell Inspiron 1150 won't start up. when i push the powerbutton the Caps lock light indicator flashes for about 10 times and then shut down
Posted on May 30, 2008
  • 56 Answers
Try taking out the can have the instructions by going to this link--- that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Posted on Dec 27, 2007
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
Dell inspiron 1150 network cable unpluged.
simple there might be settings problem . go to the network places icon in start bar and do a right click then choose Diagnose and repair..then it will works but if it says that there is a device problem then might be your router is not working correctly
Mar 17, 2010 | Dell Inspiron 1150 Notebook
Inspiron 1150 lights up but no display at startup
disconnect all power cable, battery, then press the power botton for 1min. try reset the RAM, then connect power cable and battery and press fn & power button if still it doesn't have any display then you need to change the m/b
Dec 18, 2009 | Dell Inspiron 1150 Notebook
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Dell Inspiron 1150 won't boot up. Makes a
it may come from viruses that attacked your start up, pressing F8 to run safe mode n try to scan your compter using good anti virus software
Apr 09, 2009 | Dell Inspiron 1150 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My 1150 inspiron
Sounds like a bad connection. Have it looked at by a laptop repair shop.
Jan 31, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive Logo
1,344 people viewed this question
Alun Cox
