Question about Kwikset Locks & Locksmithing
I have a kwikset lever door lock, is there a diagram or manual available for it which shows the inner mechanisim parts?
    Problem Solver:
  • 5 Answers
No. Throw it out and buy something else. Carbine, Lockwood, Brava, even Gainsborough is better than kwikset.
Posted on Oct 06, 2009
How do i attach the door lever?
http://s7d5.scene7.com/is/content/BDHHI/24910-04
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
How to tighten kwikset #991LL
Remove inside lever by loosening the setscrew and pulling. Carefully pry off the inside cover. Make sure both screws are tight. Replace inside lever. With door unlocked, the outside lever can be removed in the same way as the inside. All that is necessary though is to be sure the setscrew on the outer lever is tight. Check to be sure the lock is tight and operating correctly before closing the door and locking it.
The deadbolt inside turnbutton is held on with a small setscrew. Remove it and the inside cover. Be sure the screws under the cover are tight. Check the lock operation, replace cover and turnbutton.
Jul 07, 2014 | Kwikset 991ll 15 Smt Cp Lido Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
How can i remove a lido door lever?
You will need an allen (hex) wrench to loosen the setscrew that holds the lever. Once loosened, it pulls off easily.
Mar 03, 2014 | Kwikset 4 Lido Lh Passage Levers Satin...
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
I have a front door Kwikset "lever opening" front door key/deadbolt lock system which has come very loose, almost falling off. How do I tighten it up\?
on the inside of the door look on the bottom of the lock cover. There should be a hole with a screw or allen head screw. Remove the screw and you can access the the rest of the lock.
Feb 25, 2011 | Kwikset Professional Door Lock...
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Locks & Locksmithing Logo
662 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
