Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My 60" Philips Plasma TV Module or the board was wet by rain and my TV started smoking so a tech. for tv repair took the inside parts and said I need to order a new module
GR9D Large Signal
    Genius:
  • 1,153 Answers
Best thing to do is call PTS at 1800-844-7871, they can repair or replace. Get you back going soon.
Posted on Dec 22, 2007
My Phillips Big Screen TV is having audio problems I cannot hear anything but the picture is still great. Do you have an solution to resolve my issue?.
I would certainly challenge the fact that your SSB is bad. This SSB is known as the the small signal board. This board is a little larger than a credit card and is seated on top of the signal module( The board with all the RCA jacks and RF connections). It is located inside the TV on the left side of the rear of the TV. I must caution you, the replacement board will exceed any expectations you may have for repair. The cost of this SSB will be near $300 dollars. Then you will need a TV tech to enter the software to correct geometry. This SSB controls the screen size and colors (gray scale) and sound, etc. Sorry to lay the hard core facts. But it will not be feasible to repair this aging TV. I have seen and repaired many of these when they were under warranty! Thanks for asking and show all hands of support.
May 13, 2011 | Philips 60PW9363 60" Rear Projection...
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv started to smoke took apart and found found the
I assume it was the power supply that you replaced? It is very likely that a fusible device on another board has gone open circuit to protect any damage due to the initial problem. Again I assume you have a plasma TV in which case there will probably be a problem on the Y or Z sustain boards which may also need to be replaced as this may have been the reason for the other board to burn up
Dec 20, 2009 | Televison & Video
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
Red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Sep 09, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
My Plasma TV is in for repairs
If they are an authorized philips service center, they should know by now if parts are available. If the TV was still under warranty when you took it in for service and philips is unable to provide parts for the repair, they should give you another TV.
Good Luck.
Dec 19, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Nov 08, 2007 | Philips Smart 25TS54C 25" TV
Will not power on
this could be a number of probs. needs to be ck'd by a tv tech can usually be repaired for a few hundred bucks suggestions..audio ic,convergence ic,signal board or power module..note these parts are pricey so trouble shoot to correct part. John
Sep 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
