Question about Canon PowerShot S60 Digital Camera
The sliding part of my Canon PS S60 is lose, and
I can't get the camera's power on to slide the clamshell closed. The Lens is permanently extended, there's no power, and plugging it in or taking the battery out, charging it, and re-inserting it doesn't work. The sliding part of my Canon PS S60 is a little loose, which might be part of the problem. Help!
    Problem Solver:
  • 12 Answers
Have you checked to seee if there is anyhting stuck around the lense? if there is anyhting get a damp cloth to try and remove it
Posted on Oct 04, 2009
Nikon coolpix s60 lens error? the lens won't close.. camera works fine, but when attempting to turn off, lens doesn't close and it shows "lens error"
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Aug 17, 2010 | Nikon COOLPIX S60 Digital Camera
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Lense will not close properly
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
Tamron 28-300mm lens
Many zoom lenses of this length, and even shorter have the problem whereby the lens either extends or retracts under its own weight depending on whether the camera is pointing up or down. I had a Canon 28-105mm lens with this problem. More expensive lenses have zoom locks to prevent this from happening. $225 sound like a good price to me!
Sep 28, 2007 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Camera stopped working, lense partially extended
Switch on - lens extends - screen comes up is the normal. Partial extension of lens and the rest does not follow. Why does the lens not complete its function? Probable cause dirt got into the slide mechanism is the simple answer. Very fine mechanism- would not try anything your self. Have you a service facility of watch repair shop near you. Or try the makers web site - they may offer a swap out facility for a modest fee.
May 17, 2007 | Canon PowerShot S60 Digital Camera
The slide doesnt open
Contact this site as theres as well a toll free Tele # Good Luck http://www.nikoncamerarepair.com/
Apr 09, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Canon PowerShot S60 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
