Question about Sony Cyber-shot DSC-W55 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
I just bought this Sony camera, and ive had it a week. I just took it out to use, and during half the day, when i turned it on, the screen was black and all it read was"ACCESS" in the middle. Otherwise it doesnt let me do anything. The shutter keeps opening and closing three times, and finally, in the black background it says" turn the power off and on again" I do this, but the same results happen... HELP...
  • 22 more comments
  • Anonymous Dec 25, 2007
    Swiched on & off, recharged battery and formatted memory stick.
  • polidori Dec 27, 2007
    Yeah, the same with my sony cybershot W55. But till now, I didn´t have the guts to try something.
  • eeekamay Jan 01, 2008
    when I turn my camera on it says turn the power on and off again, what can I do to fix this problem?
  • Anonymous Jan 03, 2008
    same thing i tired the best solution thats down at the bottom and it didnt work
  • marie13080 Jan 12, 2008
    When I turn the Camera on. It comes on, but the lens keeps going in and
    out, and then it eventually goes in all the way, and the screen says
    turn power on and off again. i have turned it on and off and it does
    the same thing.
    I haven't dropped my camera and its not even a month old.
    so i don't know what could have happened to it.
    If you could help me, please contact me at my email at:
    hollister_chick_13080@hotmail.com
    my name is Marie
    Thanks
    :D
  • Squidgy Bod Jan 25, 2008
    Same as all of you on this page. But this problem is now intermittent for me. Next time it surfaces I'll try it. Just glad to realise that it's not a problem of being up in the cold, cold mountains. And it might be occurring as I don't have it in a protective case. Let's see what happens.
  • Anonymous Feb 28, 2008
    tenho o msm problema
  • firefly20 Mar 08, 2008
    I've had basically the same issue. My screen remains black and it says "Acess" on it. And after that, it says "turn camera off and on". My only difference with my problem and yours is that my lens are frozen between on and off. It does not move at all. I've tried a few solutions but none of them work. The playback button works fine, and I can easily get on that, but my camera doesn't! It makes a weird noise whenever I turn it on, I think the lens is trying to (and failing to) get unfrozen. Instead of the green light beside the Finder and Playback button, an orange light lights up.
    I really need help as this is not my camera and I NEED to fix it! Please help!
  • lauren20 Mar 12, 2008
    I turned my camera on today and it read access and the lens kept going in and out in and out i tried taking the battery out and the memory stick. even after i trun it off the lens still goes in and out for a while. I really need to fix this cause i'm going to france in three weeks...
    p.s. i tried the solution on the bottom and it didn't work
    email me at motofreak2021@yahoo.com if you have any solutions
  • Anonymous Mar 13, 2008
  • ExOhhJackie Mar 17, 2008
    I have the same problem. It happened today. I was on my way to my uncle's house and i pulled out my camera to take a picture of the beautiful mountains and boom the lense was opening and closing along with the screen that said access and had a black background. I really need it fixed.
    If anyone finds a solution please email me at lilazncrazzchick@yahoo.com
    thanks
  • Anonymous Mar 21, 2008
    I have the same problem! Screen reads ACCESS, the lens goes in and out, then it displays turn power on and off again. No help yet!
    Angela Coats
  • jbadillo Mar 25, 2008
    same issue, turns on and then reads access, finally it says turn off and on. Ive tried the re-initializing and the lens gentle push in and nothing works.
  • pinky06 Mar 27, 2008
    I have the same problem and it makes me feel better that others are dealing with this too!! i was on spring break in panama last week and after the first day my camera started doing what everyone is describing...the black screen says ACCESS and the lens opens and closes three times and then it beeps and says to turn camera off then back on again..i figured i had gotten sand in it or something but since others are describing this exact same problem, maybe i didnt do anything! i tried putting pressure on the lens, and holding the power button while this happens, but both things dont work. I just got this camera in december and id really like to fix this problem! email me at bubblebaby4688@aol.com if anyone has ANY ideas at all! THANKS
  • Anonymous Apr 04, 2008
    Hi everybody!
    I had exactly the same problem!
    The reason why it happens is that it's dust or dirt between the lenses.
    Then the lens can't expand and gets stuck.
    This is how you do: When the lens comes out you gently pull the lens outwards until it clicks. Then turn the camera of and on again and it's ok!
    And remember theres nothing wrong with your cameras, it's only the lens that can't expand! =)
    Good Luck!
    P.s. If it doesn't work, you should contact sony customers support!
    Best regards Megan J
  • megs92 Apr 04, 2008
    Hi everybody!
    This
    ok!
    Good Luck!
  • Ewel Apr 07, 2008
    My camera just did the same thing to me.
    I'm trying to solutions, people are recommending, but so far no luck.
    Ewel
  • Anonymous Apr 11, 2008
    OMG, I had the same problem, but it's an easy fix. While the lens is extracting outward, gently pull the the smaller lens away from the camera. It should click and refocus. Thanks everyone for the tip!!!!
  • Violeta88 Jun 16, 2008
    I have the same camera except in pink and i have the same exact problem.iv tried to pull the smaller lense out but nothing works and i dont want to send it to repair because it has already been broken and i dont want to pay.please helppp!!!!!
  • Froggy1191 Jun 18, 2008
    mine's doing the exact same thing...we're trying all your solutions but so far...nothing.
  • Anonymous Jul 07, 2008
    I have
  • Anonymous Sep 09, 2008
    Camera had same problem--showed access then power down and try again--In frustration I tapped it hard bottom and top and it started working
  • billnn54 Sep 18, 2008
    Since many people are having the same problem, with various successes in fixing it, it seems to me that Sony should provide everyone who has this problem with a new camera. I can't seem to make it work with any of the suggested fixes.
  • Anonymous May 18, 2009
    no it still keeps doing the same thing
  • 3 Answers
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Posted on May 30, 2009
I had the same problem..tried a new battery and that didn't work. Recharging/de-charging etc and that didn't work. I finally applied just a slight bit of pressure (pushed back towards the body) to the lens when it was fully extracted. I then turned it off and on and wala! Not a conventional solution but it worked? I guess there is a flaw with the lens extraction when power is turned on/off? Anyway hope this helps.
Cheers! Merry Xmas
Posted on Dec 23, 2007
  • santhosh_joh Dec 16, 2010
    Your idea worked, thanks a lot
  • Aquario123 Aug 21, 2011
    what do you mean push toward the body and what was fully extracted
Turn camera power on, when access appears on screen and lens extends the first time immediately hold down power button until unit powers off. Turn power on again and enjoy your camera!
Posted on Mar 22, 2008
I "solved" the problem...
But I have to do this every time I use the camera...
I pull the lens when it came out, almost when it´s totally out...
And then it works perfectly...
But I have to do thie every time so... too bad...
Maybe I will try to pull out with more power with the lens open...
Posted on Jun 17, 2008
I experienced the problem again today - why does it always happen just as you need the camera the most!!! - but could not correct it with the solution shown earlier.
I found that it was corrected by gentle pressure on the lens sleeve whilst it was closed.
Let's see what happens next time!!!
Posted on Jan 26, 2008
Mine was doing the same thing. I tried to do everything that everyone said helped their camera when they had a problem. I got so mad because nothing was working, I just pushed the lens in an held them there and I kept my hand on there, and after I just banged it with my hands at the bottom where you insert the battery, and yay it worked (;
Posted on Aug 15, 2009
A friend of mine had the same problem with his camera so i went ahead and took a look at it. I guess theres a problem with the lens for this type of camera. I don't know if it was just his or all W-55 models but i did find a way to fix it. What you do is use your nail to grab on to the the shutter of the camera  and the side of the lens. You should be able to see the glass lens. When you turn on the camera the lens motor will start to move the lens at this point pull the lens out as much as you can. When it's out all the way you can do it, turn the camera off than back on again. If it does the same "access" thing again, just try it again. I did this and it worked.
Posted on Jun 19, 2008
Jju
Posted on Jun 14, 2008
Cheers! Man I can't beleive it but it did work!!!! Dood luck to the rest of you who may have this same camera..Just keep trying it and it will finally work....
Posted on Jan 21, 2008
2 Suggested Answers
fixyathing
  • 341 Answers
SOURCE: My Sony DSC-w55 turns on and reads on ACCESS on black screen.
try to remove the battery for a few minutes this should refresh its system once you power it up again.
Posted on Aug 10, 2009
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot DSC S930 "Reinsert Memory Stick"?
Your unit is still under manufacturer warranty. I would suggest to have it repaired through a authorized Sony repair center under the warranty CLICK HERE for support for your camera. Good Luck! : )
Nov 08, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Cyber Shot DSC-W55 " Will not Access "
smack it on something, i dropped mine after 30 minutes of frustration and it started working. the next time that it happened i hit it on my table on purpose and it worked. i dont know why but this worked.
Aug 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Aug 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Access black screen problem
try this!
1.turn on the unit and switch it to play mode( by pressing the button next to th viewfinder.
2. press the menu button
3. select setup (the option with the toolbox icon)
4. inside setup look and select for setup 1(toolbox icon with a number 1 at the bottom)
5. then select initialize and select OK to every ptompt,
6. then it will pop up clock settings.
if this will not work then it would be better to hav the unit checkd and repaired by an authorized servicer. sony 1800-222-7669
Jan 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dcs w55
Go to Sony support site and check out what error C:13:01 means Then let us know
Sep 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
1,909 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
