Jetdirect config saving - Office Equipment & Supplies
2 Suggested Answers
  • 232 Answers
SOURCE: HP JetDirect J3258B asking for host name
Question is, if you DO type anything does it save then? I had a similar problem and the box was faulty. Having a host name in their won't stop it from working.
Posted on Dec 12, 2009
How to assign ip address for laserjet M4345 when it is reset at 0.0.0.0
1 Press MENU.
2 Touch CONFIGURE DEVICE.
3 Touch I/O.
4 Touch EMBEDDED JETDIRECT MENU or EIO JETDIRECT MENU, depending on which type of
network connection you are using.
5 Touch TCP/IP.
6 Touch CONFIG METHOD, and touch MANUAL.
7 Touch MANUAL SETTINGS
8 Touch IP ADDRESS
9 Touch the left arrow or the right arrow to highlight each segment of the IP address.
10 Use the numeric keypad to type the digits in each segment of the IP address.
11 Touch OK to save the IP address.
Sep 16, 2013 | HP LaserJet M4345 MultiFunction Printer
Printer not printing
Use 600N(J3113A)card instead on 620N.
Jun 06, 2012 | HP JetDirect 620N Print Server
I just moved my computer around to another room and instead of hooking it up to a switch box so several computers could use it I hooked it up only to my computer with an Ethernet cable directly. Now the...
Print a config page and check the IP address.
On the PC right click the 4050, go to properties, go to ports.
Make sure the IP address is the same as the printer.
Also on the rear of the printer, make sure that the green light on the JetDirect is on.
Check the config page (the 2nd page) right below the EIO X - JetDirect heading.
It should say "I/O Card Ready"
May 05, 2011 | HP LaserJet 4050tn Printer
J4167A jetdirect card not ready LAN ERROR-OPEN
if it is recognizing the jet direct card then the card should be good, not sure if yor network is setup for using dhcp but I usually deal with manual settings on these cards. I'm sure you know what your doing but it doesnt hurt to bounce it off others anyway.
I'll assume you know how to access the eio settings for the jetdirect from the menu screen.
choose manual setup instead of dhcp and keep all the othr settings at default except these other 3
1. You'll need to assign a manual I.P. address
2. you'll need a subnet mask I.P
3. You'll need a default gateway...
If you have other printers online then the subnet mask and default gateway should match the other printers but the actuall printer I.P address will of course be different... Hopefully this will help you out, and if so please write this a FixYa!!
Jul 19, 2010 | HP LaserJet 4100n Printer
Dec 12, 2009 | HP Jetdirect 170x Print Server
Just stop printing
turn off power, remove the JetDirect Network card if present. turn back on and see if it gets to READY state. If yes, you have a bad JetDirect card.
If still having problems, might be a formatter issue/engine board or other factor, need more info for better diagnosis.
Thank you
Jul 23, 2009 | HP LaserJet 4600dn Color Printer
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
How to setup JetDirect Plus (J2591A)
Hi Sam,
I had a similar problem and solved it, so here is a step by step. Connected to a Linksys 54G wirekess router/hub it works fine on Vista and XP, the approach is the same but some windows might look different. You may not even need the HP software at all, as Windows recognizes the HP JetDirect. Also, depending on your PC software configuration, e.g Firewall settings and router settings you may have to permanently permit various communication request. The steps below are to be understood as a guide line and may vary form yours as there are different ways to achieve the settings. On Vista, Telnet is disabled by default and needs to be enabled frist. On XP telnet is enabled by default. If you use a Linksys or similar router, you may need to enable DHCP for some addresses or range that will be used. In such case see you router manual how to do that.
Step 1:
you need to know what your LAN address is, to find out you can open a DOS window and enter IPCONFIG, this will give you the current IP address and subnet mask. On a small home network it may be 192.168.1.xxx and sbunet mask may be 255. 255. 255. 0, yous may be different. Take note of these values (IP: aaa.bbb.ccc.ddd) as you will have to set the HP JetDirect J2591A to the same address range.
Step 2:
connect the printer to the HP JetDirect, have paper in the printer, power the HP JetDirect and hold the test button on the HP JetDirect for about 7 seconds, the printer will then print the current HP JetDirect settings. You may notice the address range the HP JetDirect is set to may not be the same address range as you need it to be (your noted once)
Step 3:
connect a PC computer directly to the HP JetDirect using an Ethernet CROSSOVER cable OR connect a PC via a hub and tow standard Ethernet cables to the HP JetDirect.
Step 4:
TEMPORARELY change this PC computer network address to the same address range as the HP JetDirect address range (www.xxx.yyy.zzz) currently is set to and reboot the PC.
Step 5:
after reboot, the Status LED on the HP JetDirect should be solid on and the activity LED should be off or flashing occasionally, idicating some network traffic. Open a DOS window on the PC and run a telnet session by entering TELNET www.xxx.yyy.zzz [ENTER]. You may have to hit the Enter key tow times for a connection to start. You will then see a screen as follow:
Please type [Return] two times, to initialize telnet configuration
For HELP type "?"
===JetDirect Telnet Configuration===
Present Config : DHCP
MAC Address : 00:60:b0:ab:cb:4e
IP Address : 192.168.1.8
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.1.1
Syslog Server : 0.0.0.0
Idle Timeout : 90 Seconds
Set Cmnty Name : Not Specified
Host Name : HP_PRINTER_SERVER
DHCP Config : Enabled
Passwd : Disabled
Novell : Disabled
DLC/LLC : Disabled
Ethertalk : Disabled
Banner page : Enabled
To Change/Configure Parameters Enter:
Parameter-name: value <Carriage Return>
Parameter-name Type of value
ip: IP-address in dotted notation
subnet-mask: address in dotted notation
default-gw: address in dotted notation
syslog-svr: address in dotted notation
idle-timeout: seconds in integers
set-cmnty-name: alpha-numeric string (32 chars max)
host-name: alpha-numeric string (upper case only, 32 chars max)
dhcp-config: 0 to disable, 1 to enable
novell: 0 to disable, 1 to enable
dlc-llc: 0 to disable, 1 to enable
ethertalk: 0 to disable, 1 to enable
banner: 0 to disable, 1 to enable
Type passwd to change the password.
Type "?" for HELP, "/" for current settings or "quit" to save-and-exit.
Or type "exit" to exit without saving configuration parameter entries
Step 6:
Now you can change (likely neccessary) the HP JetDirect settings, make sure the HP JetDirect IP address is in the same range as you need it to be (for example aaa.bbb.ccc.25), also be sure to set the DHCP Config to Enabled. Optional you may want to enter a Host Name, for example: HP_PRINTER_SERVER, once you are done these new settings must be saved by entering 'quit' [Enter]. You may want to repeat Step 2 and print the new settings to convice youself the settings are retained and correct. (power cycle the JetDirect of course)
Step 7:
Connect your HP JetDirect to the intended network.
Step 8;
On the PC used to do the HP JetDirect configuration setup, restore the PC's initial network IP sddress and reboot it so it can be used again with its original settings.
Step 9:
On a PC connected to the same network as the HP JetDirect, open a DOS window and run a ping by entering: ping aaa.bbb.ccc.25 [Enter] depending on firewall settings you may have to grant permission to allow the ping to come through. You should then see a screen similar to this:
C:UsersHW_Dude>ping 192.168.1.8
Pinging 192.168.1.8 with 32 bytes of data:
Reply from 192.168.1.8: bytes=32 time=5ms TTL=60
Reply from 192.168.1.8: bytes=32 time=3ms TTL=60
Ping statistics for 192.168.1.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 5ms, Average = 3ms
C:UsersHW_Dude>
Note, there are 4 packets send and received without any loss. This is what you expect to see and great confirmation the HP JetDirect is on the network and ready. If you don't get that then there may be an issue with cabling and/or the firewall settings, you may want to double check these in such case.
Step 10:
On any PC connected to this network one can now insatll/connect to the printer that is connected to the HP JetDirect, using the Windows Add Printer Dialog, click to open the add printer wizard. Check the button for LOCAL printer (yes local, not networked !!! Who would have thought of that !? Thanks Bill G.) On the next screen that opens check the 'create new port' option and select 'Standard TCP/IP Port' OR (if available) 'HP Standard TCP/IP Port) and ckick Next. Another windows opens with TCP/IP setup wizard, click Next. An window opens, enter the HP JetDirect IP address (aaa.bbb.ccc.25) and click Next. Follow the Windows guide and finish entering the requested information. You may then want to print a Test Page once the dialog is completed, you may have to permanently allow requested traffic in the firewall settings again.
Step 11:
Your done, congratulations !
Jul 06, 2008 | HP JetDirect EX Plus Print Server
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
19 people viewed this question
k24674
jasbo
jasbo
