Question about Dell Latitude D510 Notebook
System fails to boot in normal mode and HDD self test fail
  • 20 Answers
Its time to replace your laptop's hard drive.
Jamil
Posted on Nov 18, 2009
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
HP compaq NX9420 fails to boot up; complains about system disk and i tried to install Windowsxp but it switchess itself in the process of installation
Hello Dear,
If you tried to install the windows XP on a failure HDD then it will behave like this.
You need to check your HDD first, Go to your BIOS and run the HDD Self test.
If it successful then Just format your HDD before installation it should work.
If it failed then you need to replace your HDD.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 11, 2010 | HP Compaq nx9420 Notebook
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I cannot boot my system i had a problem that smart command
SMART Stands for Self Monitoring Analsys and Reporting Technology that can predict about a probable hardware disaster in the near future and it helps you to analyse the health status of your HDD. Once you run the command and if it fails it gives you the option F1 and F2. Try to continue by pressing F2.
This should work and take you further. If it doesnt work and returns the error... possibly your HDD is under Risk. Try to work on safe mode if it goes for a boot. But all these symptoms shows a criticality on HDD and this indicates that backup your HDD and get a new one restored with this data which is backed up.
You should also see if the HDD led is flickering and that can always be a positive sign that your HDD is getting read. But no confirmation on if the Disk is read successfully or it is damaged.
Good Luck.
Feb 15, 2010 | Microsoft Windows XP Professional With...
I have a dell studio 1737 laptop i purchased in Feb of this year. my computer works for about 10-15 minutes then crashes completely. i went into safe mode and found that the consumer IR devices will not...
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Dec 05, 2009 | Dell Studio 1737 Laptop
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Wont boot into windows
Have you attempted to run in Safe mode?  Does it boot there.  If you boot to safemode and it locks on MUP.SYS most likely just the OS needs reinstalled.  Go in to CMOS (F10 on boot I think) and under tools there should be a hard drive test.
Hope this helps
Oct 28, 2007 | HP Pavilion dv1000 Notebook
Dell Latitude D510 Notebook Logo
77 people viewed this question
Alun Cox
