Eureka 2961AVZ Bagless Upright Vacuum Logo
Posted on Oct 04, 2009
CAN NOT REMOVE THE CUP THAT HOLDS THE DIRT - Eureka 2961AVZ Bagless Upright Vacuum
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
95
Points
Remove the separate "flange" component at the top of the dirt cup FIRST. Of course this is after you've moved the lever to "open". The cup should slide out easily--don't force it!
Good Luck!
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
How to open dirt devil kurv
Hi! To access the dirt cup and filter first remove the dirt cup from charger stand. Then twist the dirt cup to remove. Grab filter tab and lift up to remove from dirt cup. Twist filter to remove from adaptor. Any disassembly beyond this point is not recommended. Hope this helps!
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
Primary Filter
Exhaust Foam Filter
Hope this helps!
How do you empty it?
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
1helpful
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
I need to know how to remove the dirt container on the eureka bagless vacuum. It says that it is easy to remove, yet we cant figure it out. is there some trick to it that we dont know?
there is a lever at the bottom of the dirt cup,turn it to the left and pull out the dirt cup.note while you have the dirt cup out make sure you clean all the filters there is one right above the dirt cup pull out on the right side and there is a filter on it and at the bottom right below the dirt cup there is a door that says hepa.clean that one to.then your good to go
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
