Question about Dometic Rooftop RV Air Conditioner
Changing thermostat andcontrol box
Old control box model 3308448.004 new 3109226.005 keystone said this swap would work with existing wire when hooked up have a EE show up on thermostat also 2 wires on new control box for load shed old box did not have
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 127 Answers
SOURCE: comfort control center not working properly
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Hope this helps,
Jeff
Rate me please!!!
Posted on Jul 05, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
motor1258
  • 6674 Answers
SOURCE: problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
Posted on Aug 07, 2009
I just got a honeywell 5160 my old thermostat has an extra wire. Called support lady told us to twist together with another wire but sounded very unsure of herself. What do i do
Don't do that. It's possible the new thermostat doesn't require the C wire which is a common wire just tape it off and push it back in the wall if you have standard color coding R should be red W should be white Y should be yellow G should be green the other wire is not used. Or just match terminal for terminal with your old thermostat the leftover wire is the extra tape it off tuck it back in the wall
Jan 02, 2018 | Honeywell Heating & Cooling
Replacing an old remote car starter!
If you take it to a custom shop, they can quickly swap you out for a new module of your choosing. If you are handy and have a wiring diagram for the old module, you may be able to do the swap on your own. This is assuming the module is the only thing that needs changing.
If some problem exists in the wiring or the car, all bets are off. Electricity and electronics is not a forgiving field. Even if you are good with cars and circuits, a pro install shop would still be faster and much less of a headache.
Feb 20, 2015 | Vehicle Parts & Accessories
MY WHITE ROGERS THERMOSTAT DOES NOT HOLD THE TEMPERATURE AS DIRECTED. I COME HOME FROM WORK AND TEMP. IS 5-8 DEGREES BELOWW SETTING . I TURN IT OFF AND BACK ON AND IT WORKS FINE. THIS DOES NOT HAPPEN EVERY...
Your post didn't mention the Tstat model, if it is new or existing, what if anything might have changed near the tstat (new appliance, ceiling fan in the area) and so on. If it's new and wired correctly and the old one worked fine in the exact same mounting location, then it could be as simple as a defective tstat. If it's existing it could still be defective. On simple systems the tstat control lead for cooling turns on the condensing unit outside and the air handler inside, while the heat control lead on a non-heat pump unit turns on the air handler and heat strip. Newer systems split up the inside and outside units and control them separately to be more efficient. I don't know if you're having an issue with the heat or cool mode. If it's not the tstat then you will likely need to have a trained professional evaluate your system for system issues. Home depot carries Honeywell which Trane uses in their residential systems. Smart tstats are appearing now and while they have their advantages, putting one in an old system would be like putting a new Porsche engine in an old car with the original legacy transmission, so to speak.
Dec 06, 2014 | Heating & Cooling
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
Have a goodman central air unit, non heat pump. keeps smoking transformers, on the inside unit, replaced fan capacitor and transformer as the old transformer was smoked as well. But to no avail the new...
There is a short in the control wiring that needs to be tracked down. Ohm the wiring to the low voltage controls, ie thermostat wiring and thermostat. Try disconnecting the thermostat wires to rule out the problem in the control wiring to the thermostat or thermostat itself, then install a new transformer without connecting the thermostat wiring, jump the red and green wire at the unit low voltage connections to test blower, and then add yellow for compressor, should be no more than 3 amps on control side wiring with A/C on.
If the problems still exists without the thermostat wiring connected then there is a problem in the wiring in the unit or control board itself.
Aug 24, 2011 | Heating & Cooling
Hello? I have an existing outlet controlled by a switch with a red wire that works fine. I'm trying to swap it with new Pass & Seymour 15A CRB5262wcp6 (10-pack white) using the wiring the exact...
I am guessing this is a normal either 15a or 20a duplex recepticle and not a GFCI. When you removed the old outlet, and, if you still have it you can look at it, you should have had a black wire that hooked to the botom(gold) hot side terminal and a red wire that hooked to the upper(gold) hot side terminal. This is the side where you would have wanted to break the tab off. They can be hard to get a hold of and break completely off. It would be gold in color also, shaped kind of like a horseshoe, where you have to get in there with a scribe or small screw driver to pry on it enogh to grab it with a pair of needle nose pliers or strippers. If you did not break this tab completely off or, at least break the connection between the two outlets then, your switch won't shut off because it's double fed and can't. In the event that you broke the tab of the neutral side, only one outlet will work because you'll be missing the neutral on one of the outlets and, it still won't turn off because it's double fed. If you have the old oultlet, you can compare the old and new one and, you should be able to see where the tab had been broken off the old one. Someone with electrical expierience in say like Home Depot could point out the tab you need to break. You colud have had more than one white(neutral) wire in your box but they can either be split between the two neutral(silver) terminals or, tailed, and hooked to one, providing you did not break the wrong tab off. Of course the ground wire is pretty much self explanitory.
Jun 09, 2011 | Hammering
I purchase a 1997 Salem camper trailer and just replaced the Duo therm 13,000 Unit BTU. Everything was good until it was time to connect the wires from the thermostat unit to the analog thermostat on the...
Pay attention to wires from control box itself at the ceiling assy. Sometimes they will use a different color from control box, to thermostat. For example: Green coming out of control box, is attached to a blue running to thermostat, so you would attach that blue, to "G" (fan) on thermostat. Match thermostat colors to what is at the control box originally, not what color they used to run it to thermostat from there. Most try to match them, but others don't. What model Ac unit, and what model of thermostat do you have?
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Jan 10, 2009 | Honeywell Electronic Programmable...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
Dometic Rooftop RV Air Conditioner Logo
298 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
